call monitor
hi all,
i'm searching o software that monitor calls from a voice gateway, by giving the number of simultaneous calls for 15 days for example
Best regards
Med,
1 REPLY
Re: call monitor
The GWs do not hold all that info for that long, i'd suggest you to look instead into NMS options so you gather info via SNMP and then you can do reports with that.
java
if this helps, please rate
java
www.cisco.com/go/pdi
105
