Call on internal phones with one public number using extensions
Is any posibility to call directly from PSTN to IP Phone through one public number with extension.
I'am using UCM 6.0 and ISDN GW. There is no IVR.
Example:
PSTN ---> GW (018654987)---> IP Phones (200, 201, 202)
calling to 018654987 ext 201 and you reach phone 201
I need solution without IVR.
Patrik
Silver
Re: Call on internal phones with one public number using extensi
You can make call to PSTN using IP Phone on Publisher, but not using IP Phone on Subscriber. For that you have to configure voice gateway and call manger. The difference and the cause of the failure is here, the device manager returns an invalid pid for the non-working call, which is MGCPbrid(4,100,64,10.)
Unless I'm misunderstanding what your asking for, you can simply create a Translation Pattern. When you create the pattern you need to set the digits that are coming in from the phone company "018654987", assign it to the correct partition and then set the 201 for the Called Party Transform Mask field.
Silver
191
