call outside directly without press 9 or 0
i have H323 voice  Gateway with E1 configuration , by question is how can i call outside directly without press 9 or 0 then + mobile or home or international number ???
Ex. 967205444
i need without press 9
67205444
there is steps or notepad configuration that help me to do it ???
thanks and regards
  • IP Telephony
VIP Super Bronze
That all comes down to your dial-peer configuration. There is a reason why most PBX systems use an off-net code: to distinguish between internal extensions and off-net patterns. If you have four-digit extensions in the 2XXX range and dial a PSTN number starting with 2T you will have a problem; IOS will match the internal pattern first.
Look at your dial-peers, specifically the destination-pattern sub-command. It should start with 9 today. You can remove the 9 and just have whatever comes after it such as 67T. Just remember that any explicitly-matched digits are stripped. If you match 67T then you would need to prefix 67 to get the full number sent out to the PSTN.
Please remember to rate helpful responses and identify helpful or
thank for ur reply
you mean i have to remove 9 from this dial peer and from route pattern in the call manager
dial-peer voice 10 pots
destination-pattern 9
direct-inward-dial
port 1/0:15
please this is the confoguration i have
User Access Verification
Password:
universeE1>ena
Password:
universeE1#sh run
Building configuration...
Current configuration : 1573 bytes
version 12.3
hostname universeE1
boot-start-marker
boot-end-marker
enable secret 5 $1$Gh4n$9gV0GYwHeIXgd4K0hqG0l.
no aaa new-model
resource policy
no network-clock-participate slot 1
no network-clock-participate wic 0
voice-card 1
ip subnet-zero
ip cef
no ip dhcp use vrf connected
no ip domain lookup
no ftp-server write-enable
isdn switch-type primary-net5
voice service voip
fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback cisco
controller E1 1/0
pri-group timeslots 1-31
interface FastEthernet0/0
ip address 192.168.200.3 255.255.255.0
duplex auto
speed auto
interface Serial1/0:15
no ip address
isdn incoming-voice voice
isdn bchan-number-order ascending
no cdp enable
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.200.5
ip http server
control-plane
voice-port 1/0:15
dial-peer voice 1 voip
destination-pattern ...
session target ipv4:192.168.200.1
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
direct-inward-dial
port 1/0:15
dial-peer voice 3 voip
destination-pattern 550
session protocol sipv2
session target ipv4:192.168.180.221
dtmf-relay rtp-nte
codec g711ulaw
no vad
gateway
timer receive-rtp 1200
sip-ua
line con 0
line aux 0
line vty 0 4
password c
login
end
universeE1#
Hall of Fame Super Silver
Be very careful not to create overlaps here, as Jonathan stated there is a reason most companies use off-net access code, once you get rid of the off-net access code your options for internal extensions are limited depending on what country/state/city your deployments are in and how you dial PSTN.
HTH,
Chris
247
