Call Park CME4.2
I configured three park-slots with the same number. IP Phones can park up-to three calls by pressing Park softkey. The problem is when you want to retrieve the parked calls you can retrieve only the first call that was parked. The other parked calls cannot be retrieved and when you dial 333 (park-slot extension) says "unknown number".
Below is my configuration.
ephone-dn 145
number 333 no-reg primary
park-slot timeout 30 limit 10
description park slot for Dealing
no huntstop
ephone-dn 146
preference 1
no huntstop
ephone-dn 147
preference 2
Re: Call Park CME4.2
How would you know how to pick up the right call if they are all the same extension?
"I have a call for Bill on ext 333; I have a call for Jana on ext 333; I have a call for Greg on ext 333?"
Can you use 331, 332 and 333?
This number is programmed for sales department (3 extensions). All calls for the sales department can be answered and served by any user.
Verify both of these commands in
telephony-service to see if you get different results.
transfer-system full-consult to
transfer-system local-consult.
131
