Community Member
Call Parking @ two Phone
Dears,
We are using CCM 6.0.1
We have a requirement to configure our CCM to park calls to two different Phones simultaneously
eg. if we call Ext. 2000 it needs to ring 2000 and one external number (Mobile number) at same time. ( Not call forwarding for busy/ no answer or not hunting like ring extension if not answer go to other one)
if we pick any of the phone it should stop ringing other phones.
Looking for your valuable suggestion
Regs, Edwin
1 ACCEPTED SOLUTION
Re: Call Parking @ two Phone
Call park is a different feature and it's not related.
From what I understand what you're looking for is SNR, not call park
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
java
java
Community Member
Yes!!!, you are right...
Your information and the reference link helps a lot.
even the below link given sep by sep details.
https://learningnetwork.cisco.com/docs/DOC-4140
Wounderful......  Thanks a lot.
Edwin
330
