Call Pickup from Hunt Pilot
Hi Everybody
I have the folowing problem:
When a caller dial a office number and select de option 2 from de AA, this option routes the call to a hunt pilot that have 6 extentions associated, if any user try to pick the call the phone display "no calls no pickup" but if the caller form the AA dial any of the 6 extentions an other user try to pick up, the process was complete succesfully
Thank for your help
Hall of Fame Super Red
Re: Call Pickup from Hunt Pilot
Hi Juan,
This setup does not work without the "workaround" shown below. Once you apply this you should be good to go
**Set enterprise parameter (System->Enterprise Parameters->Cisco Support Use 1) Cisco Support Use 1 to CSCsb42763 (case sensitive)
This operation added listbox (Route Plan->Route/Hunt->Hunt Pilot->hunt pilot XXXX -> Call Pickup Group) Call Pickup Group.
From this doc;
http://www.ciscotaccc.com/kaidara-advisor/voice/showcase?case=K11612191
1.- Enter
CSCsb42763 (in mixed case) in the Enterprise Parameter 'Cisco Support
Use 1' under the new group 'Cisco Support use Only' and click update. Only the value
CSCsb42763 in this parameter can enable the configuration. Change the
value to anything else to disable this functionality.
2. Go to Hunt Pilot Configuration page and select a call pickup group from the Call
Pickup Group dropdown list and click update.
CSCsb42763
Call Pickup fails on Hunt List
Issue:
Call pickup fails for hunt list when call is CFA from Route Point in 4.1(2)ES41. This is not the designed functionality for this issue and will break the Call Pickup logic.
Workaround:
Use multiple shared lines & CFNA between each shared line.
Related Bugs
Call Pickup fails when ringing line list member
Symptom: Selecting PickUp or GPickUp does not pickup the call from any of the members of a line group. Condition: CM 4.x Workaround: None. Feature not supported. Further Problem Description: Defect CSCsa66224 may appear to have allowed this feature to work in earlier versions.
Call Pickup from line group member fails after es installed
Symptom: A call is CFNA to a hunt pilot/line group. The call can no longer be picked up. Conditions: Calls CFNA to a hunt pilot. 4.1(2)ES36. Workaround: None
Cheers!
Rob
Thanks for your help but i have call manager 7.1, the workaround is the same?
Hi Juan,
Yes, this work-around applies to CUCM 7.1 versions
as well Give it a try.
Cheers!
Rob
Hi Rob
Thanks, i'm going to try and post........
Hi Rob
It works perfectly thanks for your help
320
