Call Pickup Group Between Avaya and CUCM
I´ve seen a Cisco documents (http://www.cisco.com/en/US/solutions/collateral/ns340/ns414/ns728/ns784/713499.pdf)  describing some interoperation between CUCM and Avaya through Q.SIG over PRI(T1 or E1). The document didn´t mention Call Pickup Group between Avaya and CUCM, but still on the documment this feature is configured.
Does someone know if it is possible to configure Call Pickup Group between CUCM and other vendor platform? And if it is possible to implement these integration through PRI QSIG and/or IP trunks?
Best Regards.
Carlos Fujimura.
2 ACCEPTED SOLUTIONS
Super Bronze
Re: Call Pickup Group Between Avaya and CUCM
I've never seen Call Pickup groups work split between two systems - of the same type, or different.
For most migrations this doesn't become an issue, as you would typically migrate a department at once...
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
That's not possible, the CUCM DB does not share that information with other systems so the feature only works for phones within the same CUCM cluster.
You can configure callback over QSIG, but not call pickup
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Super Bronze
Aaron
java
java
396
