Call Pickup in one way
Hi, everyone,
I have a customer asking wether it's possible or not to configure the call pickup feature
in a way that the subscriber 'A' can pickup subscriber B's call.
but subscriber 'B' cannot pickup subscriber A's call
Thanks in advance for your help.
1 ACCEPTED SOLUTION
Hi.The first thing I can
Hi.
The first thing I can suggest, is to disable pickup feature on subscriber B phone by removing pickup softkey.
Another , a little more complex config :) is to create a pickup partitio EG PKG_PART and put the Pickup Group number into this partition.
Now you should configure 2 new CSS one containing PKG_PART and the other not eg. CSS_Pick and CSS_No_Pick and assign the first to User A line and the second to user B line.
Carlo
Please rate all helpful posts "The more you help the more you learn"
Hi.
Carlo
WAW!! Carlo,The first
WAW!! Carlo,
The first solution was simple and effective but
the second solution was really awesome, I should really have thought of that.
Thank you so much for your help, Carlos.
Glad that helped Amin.Thank
Thank you for nice rating :)
Carlo
107
