06-21-2018 12:48 PM - edited 03-17-2019 01:04 PM
Hi Guys,
My Customer is having the following problem. The Users start the external conversation and after any minutes the conversation stay mute for one side. The User not complain about call in internal site or to another sites, only local calls or long distance. Any have idea to start the troubleshooting? I speaking with the Carrier.
Wilson
06-21-2018 05:26 PM
Hi Wilsonsant
As you mentioned, it looks there is no issue for ON-Net calls, only long distance and local calls are affected.
Kindly let me know if calls are routed using MGCP/H323/SIP/CUBE Gateway.
Call Flow : IP PHone-- > CUCM --->MGCP/H323/SIP/CUBE-->Provider(ITSP/TDM)---Called Party
Is it happening for incoming or outgoing calls or both ?
Based on your call flow identify if calling Party or called party facing one way audio or both?
After how many minutes of calls one way audio starts? does it stop after some time or call mute is constantly ?
Does it happen during peak hours or randomly?
Do you have QOS implemented in your environment ?
Any recent changes made to Network, QOS policy, Firewall/ACL policy?
What is the codec used in your environment for longs distance calls G729/G711 ?
If you experience issue during peak hours, verify bandwidth assigned, DSPs on Edge device ?
Collect PCAP from source and destinations and analyze the stream, you will see from where this issue is happening ? possibly network?
Based on above Ques/Ans you will be able to isolate your issue and you can proceed accordingly, if not open a TAC case.
Prassha3
Please rate you find it helpful
06-22-2018 09:19 AM
Hi Prashant,
Thanks a lot for Your contact. Answering Your questions:
SIP and CUBE Gateway
both
Called Party
After how many minutes of calls one way audio starts? does it stop after some time or call mute is constantly?
The User informed that aproximatelly 03 minutes after start conversation. After this time the call mutye constantly
Any time
Do you have QOS implemented in your environment?
Yes
No
What is the codec used in your environment for longs distance calls G729/G711?
G711
If you experience issue during peak hours, verify bandwidth assigned, DSPs on Edge device?
No, is possible verify this about command
Collect PCAP from source and destinations and analyze the stream, you will see from where this issue is happening? possibly network?
Unfortunatelly I don´t have profile of Administrator about my machine. Yes, I believe that can be network issues. As identify this?
OK
06-30-2018 12:56 AM
