Call preservation with MGCP fallback possible?
I got a MGCP gateway w/ SRST and a T1 PRI trunk for PSTN calls. When I lost the WAN, SRST worked but I faced 2 issues:
1. Active calls didn't survive, and
2. I couldn't make outbound calls
I think I have some workarounds for the 2nd issue. However, the 1st issue is what I really wanted to get to the bottom of it. I know if I lose all callmanagers, PRI will get backhauled to the SRST router, then D-channel gets reset and my call will be dropped. Is there a way to fix this problem? I want to keep MGCP if possible.
Re: Call preservation with MGCP fallback possible?
MGCP does not support call pres with ISDN PRI or
BRI
It will work for T1 CAS and POTS
H323 call pres is the way to go. I would recommend to all only use H323 or SIP trunking. You can control you call routing much cleaner. I know it is more configuration on the front end of deployment but so many applications coming out rely on you GW to be SIP or H323. Especially if you are planing contact center at any time in you solution.
You answered your own question in your post the D Channel drops. There is no way to get around that with out going to a diffrent protocol. even with MGCP fall back.
Why are you stuck on MGCP when we all know that protocol is going away. Sorry Cisco I know you do not agree with me but I saw the writing on the wall in The 2000 's when Megaco changed to MGCP and still had to many caveauts.
This topic has been covered before. See below,
https://supportforums.cisco.com/docs/DOC-3048
-Felipe
OK I read the topic from that link before. However, I just want to confirm if I got it right. So what I would need to do is:
From the CUCM:
-  Remove MGCP gw
-  Do H.323 trunk to the SRST router
-  Make sure all off-net calls point to the SRST router which I will be converting from MGCP to H.323, i.e. the route pattern piece
From the SRST router:
-  Remove MGCP with a "no mgcp" command and anything mgcp related.
-  Put in H.323 config like pots and voip dial-peers, etc.
So does that sound about right? I wanted to try it tonight. It's been awhile I haven't touched H.323 so things might break when I switch
I just need some core config to make it work first. So if you guys got any doc or URL to start off with. That'd be greatly appreciated. Thanks.
Please check and confirm if this config is good or not. Thanks.
voice service voip
h323
  call preserve
  no h225 timeout keepalive
voice class h323 1
h225 timeout tcp establish 3
application
global
  service alternate default
interface FastEthernet0/0
ip address 10.10.10.6 255.255.255.0
h323-gateway voip bind scraddr 10.10.10.6
duplex auto
speed auto
voice-card 0
dsp services dspfarm
network-clock-participate wic 1
network-clock-select 1 T1 0/1/0
controller T1 0/1/0
framing esf
linecode b8zs
cablelength long 0db
pri-group timeslots 1-24
interface Serial0/1/0:23
no ip address
encapsulation hdlc
isdn switch-type primary-ni
isdn incoming-voice voice
no cdp enable
###### HERE ARE SOME TYPICAL DIAL PEERS #####
dial-peer voice 6000 voip
preference 1
destination-pattern 6...
voice-class h323 1
session target ipv4:20.20.20.10
incoming called-number 24..
dtmf-relay h245-alphanumeric
codec g711ulaw
ip qos dscp cs3 signaling
no vad
dial-peer voice 9 pots
description Default Outbound PSTN calls
preference 1
destination-pattern 9T
direct-inward-dial
port 0/1/0:23
dial-peer voice 911 pots
description ** 911 Calls **
destination-pattern 911
port 0/1/0:23
forward-digits all
call-manager-fallback
secondary-dialtone 9
max-conferences 4 gain -6
transfer-system full-consult
limit-dn 7910 1
limit-dn 7935 1
limit-dn 7940 2
limit-dn 7960 2
limit-dn 7970 2
ip source-address 10.10.10.6 port 2000
max-ephones 30
max-dn 60 dual-line
system message primary SRST Fallback Local
dialplan-pattern 1 XXX32624.. extension-length 4 !!!!!!!!!!!
voicemail 91XXX1234567
call-forward busy 91XXX1234567
call-forward noan 91XXX1234567 timeout 15
1660
