Call Queuing with CUCM 8 and Unity 8
I have the following scenario where i need to enable call queuing (waiting) with CUCM 8 and Unity 8
The Scenario is attached.
Now i am wondering how to configure the call handler in a way if the caller wants to talk to the operator and the operator is busy or no answer to place the call on a waiting queue and play a waiting greeting "Your call is important to us someone will be with you shortly".
Thank you and waiting for the configuration steps if possible.
1 ACCEPTED SOLUTION
With just CUCM/Unity all the call queuing you can get is in CUC/Unity and is just sending the call over and over thru a supervised tranfer to the same call handler. You'll be prompted every minute or so to press 1 to keep waiting or 2 to leave a message (that is not configurable, you'll always get that).
What you're asking for is indeed something that would require CUxAC or UCCX.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
The Scenario is attached?????
Well in the new releases of the CUCM the attendant console become different product the you can order and use for the above perp use such as simple queueing and operator call flow
The other option is to use uccx
However in the coming version of CUCM 9 ( not released yet ) there will be simple queueing builtin in CUCM
Hope this help
java
java
Thank you Javalenc foe your feedback +5.
1023
