Call Recording in Call Manager ver9.1
Dear All,
I am running call manager 9.1
Is it possible that i can records certain calls.
If yes then please provide me the procedure.
Malik
Re: Call Recording in Call Manager ver9.1
Not with only CUCM, what else you got in your network???
java
if this helps, please rate
www.cisco.com/go/pdi
java
Hi Jaime,
Thanks for the response.
I have in my network
Cisco Unity Connection 9.1
Cisco Unified Presence 9.1
Voice Gateways
IP Phones
Please feel free to ask my question.
Malik.
You can use Live Record with Unity Connection for on demand call recording.  Here's the guide for how to set this up,
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/9x/administration/guide/9xcucsag170.html#wp1071465.
Malik,
live recording is OK if you only do low volume, occasional recording. If you want more than that, like proper recording of call agents and archiving of these recordings, as well as call quality management:  use Verint, which is a third party product.
Please remember to rate useful posts, by clicking on the stars below.
169
