Community Member
Call Recording Options for CUCME?
One of my clients is a police station using CUCME/CUE.  A recent lightning strike has taken out a legacy call recording system and they are looking for a replacement.
Do you know if there are any such systems (Cisco or third party) that integrate with CUCME?
Thanks!
Re: Call Recording Options for CUCME?
You can find threads about this topic with good answers. Use the Search tool.
You can google "call recording callmanager express" and you'll find answers as well:
http://www.nice.com/products/multimedia/express.php
http://www.telrex.com/cisco_call_recording.htm
http://www.ateasystems.com/Atea%20Systems/CallRecording.html
http://www.ipcelerate.com/ipsmartsuite-cme.html
Kind regards,
- Adrian.
Hall of Fame Super Gold
As Adrian said (rated). Any "snooping-based" sytem will work.
Community Member
there is also live record which is included free.  Its limited and must be turned on by the users.  The recordings are then stored in their voicemail boxes.
Be careful if you are going to have multiple phones with the same ext (ex: softphone).  the 3rd party solutions dont work well with that case.
I think that Live Record is not scalable solution for call recording.
- Adrian
315
