Community Member
call recording
Dear all
i have cucm 7.0
i read the document about recording
after i configure SIP trunk as my recording server
what software should i user for recording?
Re: call recording
You can use something like NICE, you can search NetPro for many other suggestions or use the partner locator for recording solutions that have been tested and approved to work with CUCM 7
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Community Member
Re: call recording
I have installed Andtek's solution and can recommend it.
http://www.andtek.us/communications-products-recorder.html
328
