Call redirect after 6pm
guilherme
I have a CUCM 7.1.2 and a 2811 as H.323 gateway. Say there's a voice-port on the gateway doing connection-plar to extension "1000". What would be the best way of redirecting all incoming calls after 6 pm to another extension?
Thanks in advice.
Guilherme
Did you try to use Time period and schedule with partition realeted to PLAR? 2 different translation patterens with different partitions where you have time schedule assigned should do the job.
Check SRND for more information: http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/6x/dialplan.html#wp1044721
rate if this help
No, but I will take a look at this.
This is probably what I need so I rated anyway. Thanks!
Guilherme
