Call restriction
I have CUCM 8.6 and I want to make incoming calls restriction for some numbers, those nr. are from another Country ( not registered in CallManager ), is this posbile?
1 REPLY
Call restriction
You can configure how to reject calls on your H323 GW, or in CUCM if using MGCP, this topic has been discussed hundreds of times at CSC, a search will provide you with all the info you need on the configuration.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
67
