07-02-2008 08:13 AM - edited 03-15-2019 11:42 AM
I have Cisco 2821 router IOS version 12.4(11)XW1, with FXO ports.
incoming calls to FXO from the PSTN side rings twice before it rings on the IP phone.
I have the same issue using call manager and call manager express.
could you please advice.
07-02-2008 09:16 AM
Do you have caller-id enabled ?
07-02-2008 08:22 PM
Hi Bevilacqu,
Yes, caller-ID is enabled on the router on all FXO ports
07-03-2008 01:49 AM
You may need to upgreade to a minimum of 12.3XW to use "immediate" in "connection plar opx". Check:
http://www.cisco.com/en/US/docs/ios/12_4/12_4x/release/notes/rn2800xw.html#wp363691
Please rate post if ithelps!
