Call Routing question
Hi Everyone,
I was looking for some suggestions for a scenario that I'm looking to implement. I need the off-net inbound calls to a certain group of phones directly to go to Voicemail. But the users within the group should be able to call each other. I'm using MGCP at the Gateway.
Looking forward for your suggestions
Rohan
Re: Call Routing question
configure a CTI route point with CFA to VM that matches the set of DNs, something like 25XX or whatever you have and have the partition from that CTI under the inbound CSS of the GW but not the real partition of the phones so they can can each other without having to be CFA to VM
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
Thanks for your suggestion. I'll try it out and let you know how it worked out.
91
