erb
call routing?
                   i'd like for anyone who dials a certain extention to get a message played, then to fwd the call to an external number.  is this possible/easy?  i've got CUCM 5.1.1.3000-5 adm ver 1.1.0.0-1 and unity 4.2 build 4.2(1)  (Please don't laugh, that's our new one!)
Hall of Fame Super Silver
call routing?
Sure, configure the number as CTI Route Point and set it to call forward all to voicemail, then in Unity build call handler with the same extension, record the personal greeting and define the call handler to transfer the call to the desired number after the greeting.
HTH,
Chris
call routing?
Yes, CFA to VM and then using a call handler, configure after greeting action to another call handler with call transfer option set to call that external number.
Make sure restriction tables and CSS from VM ports allow the call.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
call routing?
HAAHAAA, unity 4.2.
Please remember to rate useful posts, by clicking on the stars below.
122
