Community Member
call search space and partitions - is there a easy way to view
Hi All
I would like to know how my css and partitions all hang together on my call manager, is there a easy way of seeing this, like a visual or table view etc ?
cheers
Hi Carl,You can try the
Hi Carl,
You can try the following. Using Bulk Administration, Export CSS data, you will get a tar file. Save that tar file in csv format. It will show the CSS names along with the list of partitions assigned to each CSS ( example output from my lab )
css.csv    60      0      0         456 12345724671  11445 0ustarccmservice     0      0 NAMEDESCRIPTIONTYPE OF PARTITION USAGEROUTE PARTITION 1ROUTE PARTITION 2ROUTE PARTITION 3
Hunt CSS GeneralHunt-Partition
ICT-CSS GeneralCSS-PhoneHunt-PartitionPT-Phone
CSS-Phone GeneralSIP-URI-PTPT-PhoneHP-PT
Forward-CSS GeneralHP-PT
Manish
I like using this from CLI
I like using this from CLI:
run sql select name as CSSname,description as CSSdescription,clause as PartitionList from callingsearchspace
91
