Call the office from Mobile Phone
Hallo,
Am having a question that i hope you are going to assist me get a way forward for.
Am having an office that we are about to implement Cisco IP Telephony-it will be based on Callmanager V8 and there will also be a 3845 Cisco gateway with E1 for PSTN connectivity.
Now most members of staff are having high end GSM phones that they use while they are away from the office for their communication.
There is a requirement that staff should use their mobile phones(mainly Nokia and blackberry) and be able to make on-net calls to the office.
What is the best way to implement this?
Rgds,
Nick.
Re: Call the office from Mobile Phone
Hi Nick,
I am not sure if this is possible, bearing in mind that your mobile users whilst out in the big bad world will be using the mobile provider's network to route calls - not your own.  (unless you network is insanely big).
It is possible to control the cost of mobile calls when in the office however, there are products available such as installing your own private gsm base station and having the mobiles connect to this whilst on site.
There may be a cheeky workaround actually.  In the UK, one of our providers (o2) offers a family bolt-on that offers free calls between configured numbers (that are o2 only).  What if you installed a gsm gateway and integrated it with CUCM and Unity.  Add this central gsm number to your users' bolt-on service and they can call it for free (in theory).  Then configure the call routing from this gsm gateway to route to Unity and set up an auto attendant to route calls or dial by extension.
It may just work, but o2 would not like it for sure.
Regards, Ash.
Have you looked at CUMA for your requirement?
Compatibility Matrix for Cisco Unified Mobility  Advantage, Cisco Mobile, and Cisco Unified Mobile Communicator
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cuma/CUMA_CUMC_Compatibility_Matrix.html
Cisco Unified Mobile Communicator Solution  Overview
http://www.cisco.com/en/US/partner/products/ps7271/product_solution_overview0900aecd805e6a3c.html
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
191
