Community Member
call to fax machine being dropped
We are using CUCM7.1(3), and try to integrate a fax server in the CUCM, call flow like this Fax server->CUCM trunk->h323 gateway->fax machine
When we do the debug isdn q931, we can see the call was setup, but after a while(around 10 seconds), the call was dropped. it seems that the far end(fax machine) send the disconnect request, please see the message
     ISDN Se 0/0/1:15 Q931: RX<-DISCONNECT pd=8 callref = 0x9393
     Cause i = 0x8090 - Normal call clearing
     Progress Ind i = 0x8288 - In-band info or appropriate now available
     ISDN Se 0/0/1:15 Q931: call_disc: PI received in disconnect; Postpone Sending RELEASE for callid 0xE0ED
If I make a call to the fax number using IP phone, there is no problem at all, the call will be released until I hang up the phone
Thank you in advance
If you are a Cisco Partner, you can email your queries to Cisco_Fax_Server@external.cisco.com .
Pls rate helpful posts.
GP.
Community Member
unfortunately we are not Cisco partner, any other suggestion regarding this issue
Hall of Fame Super Silver
Can you provide your GW config and version?
Did you configure it as T.38 fax protocol?
Chris
Community Member
Guys
Thank you for your suggestions, after I untick the option "Media Termination Point Required" in the h323 trunk between fax server and CUCM, it started to work
489
