On the HP set the CFNA and CFB to Use Personal Preferences, under the DN that forwarded the call to the HP set the call forward no coverage to VM
Just to be clear, Hunt pilot uses hunt lists and line groups
AC uses pilot points and hunt groups
They DON'T mix so please do not confuse terms specially when posting.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
