Call to PSTN taking trunks on central site
I want yo make call to PSTN  taking digital trunk of my central site when I dial from my remote site. I want to dial 3+7 digits then add the prefix 901984 to the 7 digits, after this send this digits to my central site. E1 in central site is working fine, and there is  a VPN site to site already working.
REMOTE SITE
voice translation-rule 1
rule 1 /^3\(.......\)/ /901984\1/
voice translation-profile PLAYA_POR_OJO
translate called 1
dial-peer voice 1500 voip
description a salida por OJO desde Playa
translation-profile outgoing PLAYA_POR_OJO
destination-pattern 901984.......
session target ipv4:172.16.0.1 -----> CME of central site
dtmf-relay h245-alphanumeric
ip qos dscp cs5 media
CENTRAL SITE
dial-peer voice 901 pots
corlist outgoing LADA
description LD National
destination-pattern 901..........
direct-inward-dial
port 0/0/0:0
prefix 01
with this config I can not  take trunk in central site , when I dial from remote site,,,,, I do not know why??
1 ACCEPTED SOLUTION
Silver
Re: Call to PSTN taking trunks on central site
Your dial-peer config should look like this
destination-pattern 3.......  !<---------
Since you are dialing 3+7 digit, it should match dial-peer first and then get translated on the way out.
Hope this helps.
thanks
- abu
Try changing the translation-profile from outgoing to incoming on dial-peer voice 1500 voip.
PLZ Rate if you find this helpfull.
Silver
Hope this helps.
thanks
- abu
Hi Abu,
I have already made the change suggested but still the call does not go through,
may be still something is letf
regards
Silver
can you collect
debug ip tcp transaction
debug h225 asn1
debug voip ccapi inout
thanks
- abu
Hi abu,
Finally I  found the error, in addition to change the destination pattern as you told me , I had to change the prefix in central for the dial peer.
Thanks a lot for your time
161
