Call to Voicemail pilot number disconnect from pstn
I have problem connecting to voicemail pilot from pstn, not from internal ip phone. The calls disconnected.
the connection is as below :
pstn -> vgw -> cucm -> cuc
65396789 = voicemail pilot number
96409253 = handphone number
Not sure whether is it due to telco? However the other DID range ( ip phone ) is working fine.
*Mar 6 15:01:24.194 SGP: ISDN Se0/1/0:15 Q931: RX <- SETUP pd = 8 callref = 0x0060
Sending Complete
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98392
Exclusive, Channel 18
Calling Party Number i = 0x4183, '96409253'
Plan:ISDN, Type:Subscriber(local)
Called Party Number i = 0xC1, '65396789'
*Mar 6 15:01:24.202 SGP: ISDN Se0/1/0:15 Q931: TX -> CALL_PROC pd = 8 callref = 0x8060
*Mar 6 15:01:24.210 SGP: ISDN Se0/1/0:15 Q931: TX -> ALERTING pd = 8 callref = 0x8060
Progress Ind i = 0x8088 - In-band info or appropriate now available
*Mar 6 15:01:24.274 SGP: ISDN Se0/1/0:15 Q931: TX -> CONNECT pd = 8 callref = 0x8060
*Mar 6 15:01:24.326 SGP: ISDN Se0/1/0:15 Q931: TX -> DISCONNECT pd = 8 callref = 0x8060
Cause i = 0x8590 - Normal call clearing
*Mar 6 15:01:24.370 SGP: ISDN Se0/1/0:15 Q931: RX <- CONNECT_ACK pd = 8 callref = 0x0060
*Mar 6 15:01:24.374 SGP: ISDN Se0/1/0:15 Q931: TX -> STATUS pd = 8 callref = 0x8060
Cause i = 0x82E2 - Message not compatible with call state or not implemented
Call State i = 0x0B
Please advise. thank you very much
Re: Call to Voicemail pilot number disconnect from pstn
Hi Ky,
You can try to add the command "voice rtp send-recv" in your gateway config
jp
Hi jp,
I have tried but failed. thanks any way.
Did you try a translation pattern or CTI RP to reach your pilot number
229
