Call Transfer after TCL-AA
I have CME 4.2 Version 12.4(11)XW6
TCL version is 2.1.2.2
Telepone images 8-2-2SR2
Problem is as follows;
Outside call is answered by tcl and transferred to OPERATOR
OPERATOR answers,
Press TRANSFER,
Dials EXTENSION,
Press TRANSFER again,
!!! It takes 4-5 seconds to complete the transfer. By this time Calling party appears to be HOLD and Transferred party appears to be ringing on the OPERATOR telephone !!!
I try different telephones (796x, 794x, 791x) and earlier versions than 8-2-2SR2
Nothing change.
If I disable TCL-AA, problem dissapears.
application
service queue flash:app-b-acd-2.1.2.2.tcl
param queue-len 10
param aa-hunt1 300
param aa-hunt2 302
param queue-manager-debugs 1
param number-of-hunt-grps 2
service aa flash:app-b-acd-aa-2.1.2.2.tcl
paramspace english index 1
param handoff-string aa
param dial-by-extension-option 5
paramspace english language en
param max-time-vm-retry 2
param aa-pilot 8005550123
paramspace english location flash:
param second-greeting-time 60
param call-retry-timer 15
param max-time-call-retry 600
param voice-mail 5000
param service-name queue
dial-peer voice 222 voip
service aa
destination-pattern 8005550123
session target ipv4:10.10.10.10
incoming called-number 8005550123
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
Hall of Fame Super Gold
Re: Call Transfer after TCL-AA
Not sure if would help, but can you try 8.2.2 SR4S ?
I change fw 8.2.2 SR4S
Nothing changes,
This is not releted with TCL version
I try 2.1.0.0,
Problem continues
When I disabel TCL, problem dissapears
What else can I try?
THANKS.
One more thing, try appending # after entering extension, beside that I'm afraid you might need to get the tac to reproduce and file a bug (unless one already exists). Good luck!
I've seen the exact problem with every CME we have deployed using 12.11.XJ or later.
We raised a TAC case but Cisco TAC refuse to identify it as a bug, they called it feature change.
Basically Cisco have broken the H.323 standards based supplementary services feature that are used to with transfer can call-forwarding.
The workaround is to disable these services, but it has some minor short coming if you use gatekeepers for on net calls (toll bypass).
I believe that by adding the following should resolve your issue;
voice service voip
no supplementary-service h450.2
no supplementary-service h450.3
If you can log a TAC case to help get this problem identified as a bug, contact me directly and I will provide you the existing service reference number. Maybe if more people log it as an issue it might be resolved.
I hope this helps,
Mike.
219
