Call Transfer CME-Avaya
Hi.
I need help.
In production have two telephony systems CME9.X and Avaya. Call Transfer setting full-consult on CME. When I call from Avaya ipphone on Cisco ipphone and perform call transfer on second Avaya ipphone, call transfer success. When I call from Cisco ipphone on Cisco ipphone call success, on second ipphone press Transfer, enter number Avaya ipphone, on first Cisco ipphone call pause, second Cisco ipphone and Avaya iphone call success, but when I press transfer again, that call pass from first Cisco ipphone on Avaya, call reset and short beeps.
Please help with debug.
voice service voip
ip address trusted list
  ipv4 192.168.25.0 255.255.255.0
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
redirect ip2ip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
h323
  call start slow
sip
  registrar server expires max 3600 min 3600
  asymmetric payload full
voice class codec 1
codec preference 1 g711alaw
codec preference 2 g711ulaw
codec preference 3 g729r8
voice class h323 3
h225 display-ie ccm-compatible
  call start fast
voice register global
mode cme
source-address 10.20X.X.X port 5060
bandwidth video tias-modifier 1000000 negotiate end-to-end
timeouts interdigit 2
max-dn 20
max-pool 20
authenticate register
authenticate realm all
timezone 35
time-format 24
date-format D/M/Y
tftp-path flash:
file text
create profile sync 000410054377842A
camera
video
telephony-service
no auto-reg-ephone
max-ephones 80
max-dn 80
ip source-address 10.20X.X.X port 2000
service phone videoCapability 1
service phone webAccess 1
cnf-file location flash:
cnf-file perphone
time-zone 35
time-format 24
date-format dd-mm-yy
dialplan-pattern 1 24.. extension-length 4
max-conferences 8 gain -6
call-forward pattern .T
transfer-system full-consult
transfer-pattern .T
dial-peer voice 201 voip
description TO-AVAYA
destination-pattern .T
session target ipv4:192.168.25.10
voice-class codec 1
voice-class h323 3
dtmf-relay h245-alphanumeric
no vad
Everyone's tags (4)
Green
Hi Alexander,
Try adding this to your CME config
voice service voip
supplementary-service h450.12
end
See this link:-
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/srnd/design/guide/clproc.html#wp1068396
Alex.
Please rate useful posts.
Regards, Alex. Please rate useful posts.
Hi. Thanks for answer.
Now call transfer work follows:
Cisco SCCP ipphone - Cisco SIP ipphone - Avaya ipphone - success
Cisco SIP ipphone - Cisco SCCP ipphone - Avaya ipphone - unsuccess
Avaya ipphone - Cisco SCCP ipphone - Avaya ipphone - success
Avaya ipphone - Cisco SIP ipphone - Avaya ipphone - unsuccess
Add these and then check.
voice service voip
 sip
  bind control source-interface xxxxxx
  bind media source-interface xxxxxxx
Manish
Rate all the helpful post.
480
