Call Transfer feature in a Call Handler
Unity 5.01 with ES83 patch.
After creating a Call Handler, the menu choices are:
Profile
Call Transfer
Greetings
Caller Input
Messages
I have created a schedule for the call handler.  I have gone into Call Transfer and configured and enabled both standard and closed rules.  However, the rules never seem to be active.  Everything just goes to Greetings.
What needs to happen to make things in call transfer "trigger"?
1 ACCEPTED SOLUTION
Re: Call Transfer feature in a Call Handler
Dial into Unity and then dial the DN from the CH during the greeting (as you would do to reach someone), or from another element in Unity perform an "attempt transfer" option and point to that CH.
The rules do not work on direct calls.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
java
java
Well that certainly explains why I can't get it to work.  Thanks.
153
