Community Member
Call transfer in and out through MGCP gateway
My customer has an MGCP gw in site A and H.323 gw in site B.
The receptionist at site A has the MGCP gateway as primary in her route list.
When an external call coming in through the MGCP gateway is transferred to a PSTN number, it should go out the primary gateway, but it does not.
Then the wrong caller id will show at the call destination.
Seems that the MGCP gateway will not accept inbound and outboung calls for the receptionist at the same time.
When transferring an internal call the same way, the correct gateway is used.
The protocol type is PRI Euro.
How do I fix this ?
Bronze
Re: Call transfer in and out through MGCP gateway
Use the command
ccm-manager mgcp
ccm-manager config server
ccm-manager config
http://www.cisco.com/en/US/tech/tk1077/technologies_configuration_example09186a00801ad22f.shtml
Community Member
I have put in those commands.
Now the gateway is unable to make any outgoing calls!
Inbound calls work ok.
debug isdn q931 gives this message when trying outbound:
Jun 13 11:54:05.141: ISDN Se0/0/0:15 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x800F
Cause i = 0x82AC - Requested circuit/channel not available
I tried changing the channel selection order in CCM, but it gives the same result even if debug shows that the channel changed from 31 to 1.
From the config:
network-clock-participate wic 0
network-clock-select 1 E1 0/0/0
isdn switch-type primary-net5
voice-card 0
no dspfarm
voice service voip
voice class codec 1
codec preference 1 g711alaw
codec preference 2 g711ulaw
codec preference 3 g729r8
codec preference 5 gsmfr
controller E1 0/0/0
pri-group timeslots 1-31 service mgcp
interface Serial0/0/0:15
no ip address
isdn incoming-voice voice
isdn bind-l3 ccm-manager
isdn sending-complete
no cdp enable
Community Member
After having the service provider reset the b-channels outgoing calls can be made again.
But when the switchboard operator transfers inbound calls to an external number, CallMgr still routes the call through the wrong gateway.
Debugging shows that there is no attempt to use the correct gw, so I guess we have to look at the switchboard software or CM config.
271
