05-28-2007 05:39 AM - edited 03-14-2019 09:44 PM
hi, i have configured CME and CUE, all IP phones works normaly, but the transfer call do not work normaly, the person who do the transfer can not talk with the destination to know if he want to take the call or not, the transfer is done automaticly without consult of the person, please i wanna to solve this problem, because in other configuration of CME without CUE the transfer call work with consulting. i hope that i have explinaid well the problem, Thanks
05-28-2007 05:54 AM
Hi Abderrahim,
In CME you have have a sytem wide Transfer setting (transfer-system {blind | full-blind | full-consult [dss] | local-consult} as well as the ability to override this setting on a phone by phone basis (ephone-dn dn-tag [dual-line] **transfer-mode {blind | consult}). You probably need to choose something like transfer-system full-consult. Have a look at the following;
Configuring Call Transfer
This procedure enables support for network calls that use the H.450.2 standard and allows you to optionally specify a range of allowable transfer destinations.** It also allows you to override the global setting for blind or consultative transfer for individual ephone-dns and block transfers to external destinations by individual ephones.
SUMMARY STEPS
1. enable
2. configure terminal
3. telephony-service
4. transfer-system {blind | full-blind | full-consult [dss] | local-consult}
5. transfer-pattern transfer-pattern [blind]
6. exit
7. ephone-dn dn-tag [dual-line]
8. transfer-mode {blind | consult} **
9. exit
10. ephone-template template-tag
11. transfer-pattern blocked
12. transfer max-length digit-length
13. exit
14. ephone phone-tag
15. ephone-template template-tag
16. restart
17. Repeat Step 14 to Step 16 for each phone on which you want transfer capability limited.
18. end
Use the show running-config command to verify your configuration. Transfer method and patterns are listed in the telephony-service portion of the output. You can also use the show telephony-service command to display this information.
If you have used the transfer-mode command to override the global transfer mode for an individual ephone-dn, use the show running-config or show telephony-service ephone-dn command to verify that setting.
This would show up like this;
ephone-dn 40 dual-line
number 451
description Main Number
huntstop channel
no huntstop
transfer-mode blind**
From this good doc;
Hope this helps!
Rob
05-28-2007 07:09 AM
Thanks, it's extremly helpful for me, i will test it, but i wanna know why with a default configuration of CME in other labs that i do,the call transfer work normally without any added configuration, Thanks
05-28-2007 07:26 AM
Hi Abderrahim,
The default for this Parameter changed between CME 3.3 and CME 4.0 (from blind to full-consult) maybe this is what you are seeing :)
Cisco Unified CME Version 4.0 and later transfer-system Command Default = full-consult
Cisco Unified CME Version 3.0 to 3.3 transfer-system Command Default = blind
From this doc;
Hope this helps!
Rob
05-28-2007 11:50 PM
ok, i will do this configuration, i hope that it will work normaly, thanks for all Rob,
Abderrahim
05-29-2007 06:54 AM
hi Rob,
finaly it work normaly now, the problem was in the Dual-line, before i had a single DN, i had delete thos DN, and i had created a dual-line DN. Thanks
Abderrahim
05-29-2007 06:58 AM
now i have another question, in my CME i have registred a mac address with an ephone, than i want to regiter another mac address in this ephone after deleting the first, the problem that i can't do it, the first mac address is in database, i want to delete this mac address for this ephone to adding an other. Thanks
