Call transfer issue with SPA phones with 7911 operator phone
hello all
i am having issue regarding call transfer from operator phone 7911 and rest of SPA phones 50x and 525g2 phones,when operator transfers a call SPA phones rings and when we pick up transfer call on spa it gets disconnected , on the other hand same operator can transfer calls to 7945 phones successfully. please let me know what is the issue behind this here is my debug isdn q931
May  6 12:39:34.995: %SM_INSTALL-6-INST_RBIP: ISM0/0 received msg: RBIP Registra
tion Request
May  6 12:39:38.099: ISDN Se0/0/0:15 Q931: RX <- SETUP pd = 8  callref = 0x0001
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA98381
                Exclusive, Channel 1
        Calling Party Number i = 0x0180, '03214689910'
                Plan:ISDN, Type:Unknown
        Called Party Number i = 0x81, '00924232560257'
        Sending Complete
May  6 12:39:38.099: ISDN Se0/0/0:15 Q931: Received SETUP  callref = 0x8001 call
ID = 0x0001 switch = primary-net5 interface = User
May  6 12:39:38.107: ISDN Se0/0/0:15 Q931: TX -> CALL_PROC pd = 8  callref = 0x8
001
May  6 12:39:38.127: ISDN Se0/0/0:15 Q931: TX -> ALERTING pd = 8  callref = 0x80
01
May  6 12:39:39.207: ISDN Se0/0/0:15 Q931: RX <- SETUP pd = 8  callref = 0x0002
                Standard = CCITT
        Channel ID i = 0xA98382
                Exclusive, Channel 2
        Calling Party Number i = 0x0180, '35764583'
        Sending Complete
May  6 12:39:39.211: ISDN Se0/0/0:15 Q931: Received SETUP  callref = 0x8002 call
ID = 0x0002 switch = primary-net5 interface = User
May  6 12:39:39.215: ISDN Se0/0/0:15 Q931: TX -> CALL_PROC pd = 8  callref = 0x8
002
May  6 12:39:39.231: ISDN Se0/0/0:15 Q931: TX -> ALERTING pd = 8  callref = 0x80
02
May  6 12:39:44.991: ISDN Se0/0/0:15 Q931: TX -> CONNECT pd = 8  callref = 0x800
May  6 12:39:45.019: ISDN Se0/0/0:15 Q931: RX <- CONNECT_ACK pd = 8  callref = 0
x0001
May  6 12:39:53.335: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/0/0
:0, changed state to up
May  6 12:40:02.995: %SM_INSTALL-6-INST_RBIP: ISM0/0 received msg: RBIP Registra
tion Request
May  6 12:40:07.635: ISDN Se0/0/0:15 Q931: TX -> DISCONNECT pd = 8  callref = 0x
8001
         Cause i = 0x80AF - Resource unavailable, unspecified
May  6 12:40:07.659: ISDN Se0/0/0:15 Q931: RX <- RELEASE pd = 8  callref = 0x000
May  6 12:40:07.659: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8  callref =
0x8001
May  6 12:40:18.443: ISDN Se0/0/0:15 Q931: RX <- DISCONNECT pd = 8  callref = 0x
0002
        Cause i = 0x8090 - Normal call clearing
May  6 12:40:18.443: ISDN Se0/0/0:15 Q931: TX -> RELEASE pd = 8  callref = 0x800
May  6 12:40:18.471: ISDN Se0/0/0:15 Q931: RX <- RELEASE_COMP pd = 8  callref =
0x0002
May  6 12:40:31.995: %SM_INSTALL-6-INST_RBIP: ISM0/0 received msg: RBIP Registra
tion Request
CNS-RTR-1#no term
CNS-RTR-1#no terminal monitor
Question:Are they able to
Question:
Are they able to transfer internal calls with the same results?
yes they are making external
yes they are making external calls and registered as a SIP device, no firewall between them , we have upgraded 525 to the latetst firmwre and changed codec to 711 only then its working fine, becuase we are using codec 711 for incoming calls, we are doing same with lets see if its succeful i will let you know
Ah, yes. That was going to be
Ah, yes. That was going to be my next question!
Let me know how it turns out.
yes we have changed codec on
yes we have changed codec on SPA to 711u and disabled g722 from spa and from CUCM also we have disabled g722 from enterprise parameters in this way they working now, but Cisco TAC advised us to configure MTP on Gateway.
Yeah, an MTP will definitely
Yeah, an MTP will definitely resolve this issue, and is the "correct" option.
Please see: http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/admin/8_5_1/ccmsys/accm-851-cm/a05mtp.html
This should give you a good starting point in configuring your MTP services in the future.
Also disabling g722 on enterprise parameters is also not a bad idea, especially considering they can cause issues if you have a mixture of wideband phones and non-wideband phones.
Also make sure you have configured your regions between sites to correctly negotiate codecs, please see:
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/admin/7_0_1/ccmcfg/701-cmcfg/b02regio.html
This will give you a good start in configuring regions correctly.
yes internal calls are ok but
yes internal calls are ok but when operator transfer to spa 504 and 525 call get disconnected/
Are these registered to the
Are these registered to the same phone system?
Are you able to make external calls to the SPA phones?
Are they registered via SIP or SCCP?
Is there a firewall between the phones and the phone system?
51
