Call Transfer issues Hipath - Callmanager
I have the following flow of calls:
Scenario A
1- Ext. 5678 (IP) from Siemens hi-path receives one call from pstn.
2 -Ext. 5678 puts on hold and try transfer the call to 2199 (7912G) from Callmanager. When 2199 is busy and the field "Forward Busy Internal" or "Forward Busy External" within "Call Forward and Call Pickup Settings" is configured to transfer to ext. 2754 that is busy too, the callmanager responds Cause i = 0x819F - Normal, unspecified or Special intercept, call blocked group restriction;
Scenario B
1 - Ext. 5678 (IP) from Siemens hi-path receives one call from pstn.
2 - Ext. 5678 puts on hold and try transfer the call to 2199 (7912G) from Callmanager. When 2199 is busy and the field "Forward Busy Internal" or "Forward Busy External" within "Call Forward and Call Pickup Settings" is "default", the Callmanager responds "Cause i = 0x8591 - User busy"
The problem is that in scenario "A" the 5678 does not hear the busy tone and Lost the call from pstn and the call to extension from callmanager (2 Call Legs).
In scenario "B" the Hi-Path extension 5678 hears the tone of busy and recuperates the call normally.
Exists a workaround to callmanager answer "busy" on scenario B or is the Default behavior?
Cause i = 0x819F - Normal, unspecified or Special intercept, call blocked group restriction is like Busy?
The topology is attached.
Tks!!
Green
Re: Call Transfer issues Hipath - Callmanager
I see your email, been pretty busy these days here,
What is the exact cucm version, and IOS versions.
Can you upload cucm sdi,sdl traces and gw debugs from cisco side.
It follows in annex a file with more details.
Thanks for all!
Faria Lima's site 62.102.96.17
na-basf-sao2a-sao-am>sh ver
Cisco IOS Software, 2800 Software (C2800NM-SPSERVICESK9-M), Version 12.4(12c), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Fri 13-Jul-07 03:05 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
na-basf-sao2a-sao-am uptime is 18 weeks, 3 days, 21 hours, 21 minutes
System returned to ROM by Reload Command
System restarted at 23:42:53 CEST Sat Apr 18 2009
System image file is "flash:c2800nm-spservicesk9-mz.124-12c.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 2821 (revision 53.51) with 251904K/10240K bytes of memory.
Processor board ID FTX1236A25K
4 FastEthernet interfaces
2 Gigabit Ethernet interfaces
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
125440K bytes of ATA CompactFlash (Read/Write)
Demarchi's Site: 62.102.96.18
na-basf-sao1a-spl-am#sh ver
na-basf-sao1a-spl-am uptime is 26 weeks, 2 days, 8 hours, 6 minutes
System returned to ROM by Reload Command at 10:57:16 UTC Mon Feb 23 2009
System restarted at 12:00:05 CET Mon Feb 23 2009
Network configuration file is "tftp://168.125.7.206/11045-2.push"
export@cisco.com.
Processor board ID FTX1236A26Q
Hi Eduardo.
Do you you solved this problem?
Peterson
No. I awaiting a answer...
Gogasca, can you help me?
Thanks!
367
