Community Member
Call Transfer on CCME (Incoming SIP to internal)
Hi all,
I have a CCME(C2800NM-SPSERVICESK9-M), Version 12.4(9)T1 with Version=4.0(0).
The CallManager Express is connected with the SIP-Provider.
SIP inbound and oubound calls are working well. The problem is that I'm not able to transfer (internal/external) or park an incoming SIP call (when it's picked up on the IP-phone).
Here the partial config:
voice-card 0
no dspfarm
voice call convert-discpi-to-prog
voice disc-pi-incoming-on
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
no supplementary-service h450.3
sip
voice class h323 1
h225 timeout tcp establish 3
call start slow
call preserve
dial-peer voice 999 voip
description *** VOICEMAIL ***
destination-pattern 999
session protocol sipv2
session target ipv4:192.168.115.10
dtmf-relay sip-notify
codec g711ulaw
no vad
dial-peer voice 200 voip
description *** SIP-TRUNK (IN) ***
translation-profile incoming TP_IN_SIP
translation-profile outgoing TP_OUT_SIP
service session
max-conn 4
destination-pattern 081544009.
session target ipv4:212.x.198.140
session transport udp
incoming called-number 081544009.
dtmf-relay sip-notify rtp-nte
codec g711ulaw
no vad
dial-peer voice 210 voip
description *** SIP-TRUNK (OUT) ***
service session
max-conn 4
destination-pattern 0.T
codec g711ulaw
no vad
gateway
timer receive-rtp 1200
sip-ua
authentication username xxx password xxx
no remote-party-id
retry invite 1
retry response 1
retry bye 1
retry register 10
registrar ipv4:212.x.198.140 expires 60
offer call-hold conn-addr
reason-header override
telephony-service
load 7960-7940 P0030702T023
load 7914 S00104000100
load 7905 CP7912040000SCCP040701A.sbin
load 7902 CP7902080001SCCP051117A
load 7970 TERM70.7-0-3-0S
load 7912 CP7912080002SCCP060817A.sbin
max-ephones 52
max-dn 192
ip source-address 192.168.115.1 port 2000
timeouts interdigit 4
system message TEST
url services http://192.168.115.1/localdirectory
user-locale DE
network-locale CH
time-zone 21
time-format 24
date-format dd-mm-yy
voicemail 999
max-conferences 8 gain -6
call-park system redirect
call-forward pattern .T
call-forward system redirecting-expanded
web admin system name xx password xx
dn-webedit
time-webedit
transfer-system full-consult
transfer-pattern .T
secondary-dialtone 0
directory last-name-first
ephone-dn 1 dual-line
number 200 no-reg primary
label number(200)
description number(200)
name number(200)
huntstop channel
ephone-dn 3
number 220 no-reg primary
label number(220)
description number(220)
name number(220)
ephone-dn 100
number 800 no-reg primary
park-slot timeout 20 limit 10
ephone-dn 190
number 8001... no-reg primary
mwi off
ephone-dn 191
number 8000... no-reg primary
mwi on
ephone-dn 192
number 0815440097
ephone 3
username "user200" password 12345
mac-address 0014.6A9C.424D
type 7970
button 1:1
ephone 5
username "user5" password 12345
mac-address 0016.478B.0716
type 7940
button 1:3
Any suggestions ?
Thanks in advance
Norbert
Hall of Fame Super Gold
Re: Call Transfer on CCME (Incoming SIP to internal)
Hi Norbert,
I've just tried transferring an incoming SIP call from one extension to another and worked fine.
I'm using CME 4.1 and I've not even configured a dial-peer for the incoming SIP, just calling from a softphone.
So I'm unable to tell you if it is a configuration issue or what, but it works for me.
Only, pls check that all phones involved are configured for dual-line.
Bronze
Hi Norbert,
The problem is that prior to CME 4.1, whenever a call if forwarded or transferred, the CME sends a SIP 302 - Moved temporarily message back to the SIP provider. When the provider got this message, it didn't know how to route to the new number because the SIP provider was statically provisioned. Here are 2 options:
(1) Upgrade to CME 4.1. With this new code, the CME does not send SIP 302 message and locally transfers the call
(2) If you wish to stay on 12.4(9)T - CME 4.0, then you need to configure an inbound dial-peer and add the following command:
service session
This will cause the CME to locally transfer/handle the call.
Hope this helps,
Tony
Community Member
Thanks all for the reply.
For information, if I do a "call forward all" on the IP-Phone it works (internal and external).
I had the "302-Moved temporarly" problem and it was solved by the second SIP dial-peer.
@Tony
Which kind of inbound dial-peer do you mean?
Thanks again,
Norbert
Community Member
Hi Tony,
I'm having exactly the same problem here. I've been waiting for the CME 4.1 release for months, now it's here :-)) and I'd love to get this working.
I still have the "service session" command in the dial-peers, and I'm unable to remove it ("no service session" is not recognized?). Anyway, the symptoms are that if I try to transfer a call coming from the outside (SIP dial-peer) to another inside or outside number (through another SIP dial-peer or to an SCCP phone), whenever I push "transfer" both calls are just placed on-hold (I see the "pause" icon on the phone, a 7961) and nothing happens.
I have also enabled the following commands:
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
(because the ISP - as in ourselves - don't support those SIP commands).
How can this be solved?
Thank you
-Manuel
Community Member
OK, I'm replying to myself here - I had to remove and re-add the dial-peers without the "service session" command. Now transferring and forwarding works correctly. Thanks for this new release!
-Manuel
Community Member
Hi all,
Sorry for the delay.
Transfer is now working without "service session" on the dial-peer and the following entries (CME 4.1):
Thanks all for the help.
Greets,
Norbert
627
