Call transfer problem with cisco voip gateway
hi,
In my environement, i have CCM 7.0 and 2 gatways h323 3825 and 2811 (all within same Vlan). the 2 gateways are configured the same way but the call transfer works fine with the 3825 gateway but it does not with the 2811 one.
any ideas?
1 ACCEPTED SOLUTION
Bronze
Re: Call transfer problem with cisco voip gateway
Please rate succesful answers
Cheers
Mark
Bronze
Do you have MTP checked on both gateways?
Mark
thx you for your reply
I check MTP on both gateways, it worked.
the weird thing is that the transfer worked fine with the 3825 gateway without checking this parameter.
Bronze
Cheers
Mark
279
