11-02-2009 08:20 AM - edited 03-15-2019 08:20 PM
HI Folks,
I want to restrict the national call transfer option for one group of users(not all clusters users) but they should have internal call transfer option.
11-02-2009 08:40 AM
Do you apply CoR (class or restriction) at the line (recommended) or at the device?
11-02-2009 09:04 AM
i have CUCM 5.1.3
11-02-2009 10:35 AM
In CM 5.1.3 calling restrictions are not based on just the transfer option. You can only restrict call forwarding to a destination. So with that being said you will have to restrict the phone as a whole by using your CSS. The only other way that i can think of off hand is to send through a gateway enabled with CME and specify CoR on your dialpeers. Not clean at all and requires another device to mediate the traffic.
