Community Member
Call transfer
A phone is set up to take 4 calls on the same line no.
When a call is answered the user will try to make a transfer but if another call comes in at the same time, we are unable to transfer the first caller.
do i need to do something on the config
1 ACCEPTED SOLUTION
Re: Call transfer
dear,
when a second call came, the selection automatically goes to the new call
So select the first call using the up key and then use transfer
Eldho
1 REPLY
Re: Call transfer
dear,
Eldho
133
