Community Member
Call Transfer
Dear All,
I m running CME 4.2...problem which i m facing is that, when somebody calls me from outside the call does not transfers to my cell fone..it gives busy tone...plz note that we are using E1 line...plz find below my specific config for call transfer...
telephony-service
transfer-system full-blind
transfer-pattern .T
ephone-dn 14 dual-line
number 9898
label 9898
description Technical Support
name Technical Support
call-forward busy 0507649312
call-forward noan 0507649312 timeout 10
corlist incoming GROUP-4
hold-alert 30 originator
ephone 38
video
mac-address 001B.53C6.324E
paging-dn 2
type 7912
button 1:14
Please note that extension number is 9898 and the cell number on which i need the outside call to be transfered is 0507649312. Locally it works fine...like for example if no body picks the call on extension 9898 it get transferd to my cell fone...but when an outside call comes to extension 9898 and if no body answers the extension, it gives busy tone...
Please advice me if i m doing any mistake...or i need some additional configuration...
your consideration in this regard will highly be commendable.
Thanks Malik.
Re: Call Transfer
hi Malik
i will assum you dial-peer it ok as you mentioned if the call come internally and not answered it get forwarded normally
do the follwoing command
voice service voip
wish this will solve your issue
good luck
Community Member
Re: Call Transfer
thanks for your reply...but dear this command it already there...any other suggestion will be helpfull...
Hall of Fame Super Gold
Re: Call Transfer
Please take "debug isdn q931" with "term mon" for a failed transfer. Do not enable other debugs, do not include other calls, do not use attachments.
Community Member
Re: Call Transfer
boss this command is not working on my router...plz advice..
thanks,
malik...
122
