Call transfers drop on CME to CME sites
On CME sites, call transfers are getting dropped from site B to site A but calls from site A to site B are not. People make a voip call across the network. Reach the person. Wnen the caller gets transferred by that person they hear a second or two of MOH then the call just drops. Call forwarding works however. And calls from the PSTN transfer fine. There are 30 CME sites and some sites drop the call transfers and other sites the calls go through. The IOS is ver 12.3.11T8 and the CME ver is 3.2. The basic configs are all the same on the CMEs.
What debugs can I use to troubelshoot this?
This problem occured with calls from a CCM site to CME sites, but I Checked the MTP Required box on the gateway configuration page and now the calls from a CCM site to a CME site will transfer. Thanks for any ideas.
Site A configs
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
supplementary-service h450.12
h323
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
dial-peer voice 7731 voip
corlist outgoing offsitevoip
description To SITE B Site to Site
translation-profile outgoing out-strip-8
destination-pattern 8731....
voice-class codec 1
session protocol sipv2
session target ipv4:172.65.2.9
dtmf-relay h245-alphanumeric
ip qos dscp cs5 media
no vad
telephony-service
load 7910 P00403020214
load 7960-7940 P00303020214
load 7914 S00103020002
load ATA ata18x-v2-16-ms-030327b
load 7905 CP79050101SCCP030530B
max-ephones 70
max-dn 140
ip source-address 172.75.2.9 port 2000
system message XXXXXXXXXXXXXXxx
create cnf-files version-stamp 7960 Mar 08 2004 15:30:22
dialplan-pattern 1 7305... extension-length 4 extension-pattern 5...
voicemail 1000
mwi relay
max-conferences 8
moh music-on-hold.au
multicast moh 239.10.16.4 port 2000
web admin system name XXXXXXXXXXXXX
web admin customer name XXXXXXXXXXXXX
dn-webedit
time-webedit
transfer-system full-blind
transfer-pattern 9.......
secondary-dialtone 9
SITE B
voice call send-alert
voice rtp send-recv
voice service voip
no supplementary-service h450.2
no supplementary-service h450.3
h323
voice class codec 1
dial-peer voice 7730 voip
description To SITE A Site to Site
destination-pattern 8730....
voice-class codec 1
session target ipv4:172.75.2.9
no vad
telephony-service
max-ephones 70
max-dn 140
ip source-address 172.65.2.9 port 2000
system message SITE B
create cnf-files version-stamp Jan 01 2002 00:00:00
dialplan-pattern 1 7315... extension-length 4 extension-pattern 5...
voicemail 1000
mwi sip-server 172.65.2.9 transport tcp
mwi relay
mwi expires 86400
max-conferences 8
web admin system name XXXXXXXXXXXXXXXXXXXXX
web admin customer name XXXXXXXXXXXXXXXXXX
dn-webedit
time-webedit
transfer-pattern .T
Re: Call transfers drop on CME to CME sites
Do you have the h323-gateway voip bind srcaddr "ip-address" on your ethernet interfaces?
I have that command under the loopback interface of all the CMEs.
Every get an answer to this, having a similar issue.
176
