04-05-2014 10:49 AM - edited 03-16-2019 10:23 PM
i am doing a parallel migration from CUCM 7 to CUCM 9. i have an ICT trunk between the systems, but call transfers through the trunk doesnt seem to work.
can any give some guidance.
thanks,
Surendra
Solved! Go to Solution.
04-06-2014 12:58 AM
04-22-2014 10:30 AM
04-06-2014 12:58 AM
04-22-2014 09:59 AM
HI Suresh,
thanks for your response, my issue was resolved. MTP was the source of my issue :)
04-22-2014 10:30 AM
04-22-2014 10:46 AM
hello Surendra,
Is your ICT trunk between CUCM7 and CUCM9? can elaborate the transfer flow ?
Did you collected the ccm traces ?
Br,
nadeem
