Call transfers through ICT trunk not working
i am doing a parallel migration from CUCM 7 to CUCM 9. i have an ICT trunk between the systems, but call transfers through the trunk doesnt seem to work.
can any give some guidance.
thanks,
Surendra
2 ACCEPTED SOLUTIONS
Do you have MRGL configured
Do you have MRGL configured on the trunks with MTP & MOH? What type of trunk you have configured between cluster? Direct calls between these clusters are working fine? Are you able to hold /resume this intercluster call?
//Suresh Please rate all the useful posts.
Thanks for the update
Thanks for the update Surendra. Good to know the issue is fixed. //Suresh Please rate all the useful posts
HI Suresh, thanks for your
HI Suresh,
thanks for your response, my issue was resolved. MTP was  the source of my issue :)
hello Surendra, Is your ICT
hello Surendra,
Is your ICT trunk between CUCM7 and CUCM9? can elaborate the transfer flow ?
Did you collected the ccm traces ?
Br,
nadeem
Br, Nadeem Please rate all useful post.
68
