Call trasfer
Hiii,
I have a SIP with Avaya and I want  CallManger to receive the  the last 4 digits from Avaya, from where I have to do the change?
SIP/Trunk Profile?
Th!
Call trasfer
Hi Gabriel,
On the SIP Trunk, Under "Inbound Calls" > "Significant Digits" , set this value to 4 and reset the SIP trunk.
Manish
Call trasfer
And if the Avaya sent  7 digits and I want to receive only the last 4 is the same settings?
Call trasfer
Yes.
Manish
Hello, Still not working, i
Still not working, i made the config from this documentation:
http://www.cisco.com/c/dam/en/us/solutions/collateral/enterprise/interoperability-portal/966105.pdf
The config end at page 29-30 because the providers he said  is not necessary to add on Call Manager, what do you think about this?
have you set up the SIP trunk
have you set up the SIP trunk following the above guide (p-20 to 25)?
please crosscheck whether you have set the significant digits to 4 under Inbound Call settings (p-24)
Through RTMT session trace, you can check these SIP Trunk calls and its flow.
Please collect the CCM traces for a nonworking call and provide the calling, called party numbers.
//Suresh Please rate all the useful posts.
Yes from 20/25.This from a
Yes from 20/25.
Could you please collect the
Could you please collect the traces from CUCM using RTMT?
Here is the guide: https://supportforums.cisco.com/document/126666/collecting-cucm-traces-cucm-862-tac-sr
Hello, This colect from RTMT
This colect from RTMT and open with CUC Tracer Translator.
03/21/2014 07:54:58.136 |//SIP/SIPTcp/wait_SdlSPISignal: Outgoing SIP TCP message to 10.200.160.1 on port 5060 index 105222
[6799248,NET]
OPTIONS sip:10.200.160.1:5060 SIP/2.0
Via: SIP/2.0/TCP 10.156.100.1:5060;branch=z9hG4bK1afb027e54e6
To: <sip:10.200.160.1>
Date: Fri, 21 Mar 2014 05:54:58 GMT
Call-ID: 5438aa80-32b1d432-1a559-5c4d90a@0.156.100.1
User-Agent: Cisco-CUCM8.6
CSeq: 101 OPTIONS
Contact: <sip:0.156.100.1:5060;transport=tcp>
Max-Forwards: 0
Content-Length: 0
Source Filename: ccm00000191.txt.gz
401
