tka
Call types configuration / CDR
Hi all,
Could some one explain to me how is CAR toll able to distinghuish between Call types :
- On Net
- Internal
- Local
- Long Distance
- International
- Incoming
- Others
whereas actually, I is only possible to select ON NET or OFF NET when configuring route patterns.
Thanks in advance.
1 ACCEPTED SOLUTION
Re: Call types configuration / CDR
you define dial plan rules in CAR to decide that, you can change it accordingly to the digits dialed and number of digits to mark the call as one of the types you mention
java
if this helps, please rate
java
www.cisco.com/go/pdi
1 REPLY
java
java
94
