Call Waiting 9.1
Dears,
How a call waiting can be know to caller,incase the called number is on another call.
1 ACCEPTED SOLUTION
Call Waiting 9.1
You will see the second call on the phone and, depending on your config, hear a tone to indicate the call.
If you mean you want this for whoever is calling, and not the called party, not possible.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Re:Call Waiting 9.1
Do you have the "number of calls" and "busy trigger" set to 2 or more under the line configuration of the phone?
Yosh
Sent from Cisco Technical Support Android App
HTH Regards, Yosh
Re:Call Waiting 9.1
Yosh
HTH Regards, Yosh
Re:Call Waiting 9.1
Dear yashsiel,
yes it is confgured
maximum number of calls 4
busy trigger  2
what i want to achieve is that caller should come to know on his screen "call waitng"
Call Waiting 9.1
java
java
Call Waiting 9.1
Thanks Jaime,
To hear a tone
what i have to do to hear a tone
yes this is i want and this is not possible, thanks for the confirmation
147
