02-15-2012 06:07 AM - edited 03-16-2019 09:36 AM
Hello all,
I'm trying to use Callback feature over an ICT without success. I get "Callback cannot be activated on" message.
While on the same cluster everything is fine; I cannot make it work between different clusters.
Does anyone got some hints or a similar experience?
thanks
Lorenz
02-15-2012 06:25 AM
Unless you're talking about a QSIG enabled ICT then it's expected to fail
Cisco Call Back
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/8_6_1/ccmfeat/fscallbk.html
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
02-15-2012 06:39 AM
i fixed it by adding QSIG support under tunnelled protocol on every trunk.
it's working.
