Callcentric Outbound Caller ID (Remote-Party-ID)
Hi all - another quick question about controlling the outbound caller ID presented to Callcentric SIP Trunks via the Remote-Party-ID field. I spoke with Callcentric Support and will adjust your outgoing caller ID to a DID on your account if you specify it in the Remote-Party-ID field in the format below (this is with one of my test DIDs).
Remote-Party-ID: "18452055545" <sip:18452055545@callcentric.com>;
I did a trace and here's what I see when I send a call to Callcentric - this is the default action by CUCM/Cube. The 'Name' portion shows the external number mask associated with the DN calling out. The URI however is the username with Callcentric and as such they dont adjust the caller ID - I get the default caller ID associated with 17772253754.
Call flow for outbound is CUCM -> CUBE -> ISTP.
Cube is running Version 15.1(4)M7.
Cube IP is 192.168.1.203
CUCM IP is 192.168.1.200
INVITE sip:18165297500@callcentric.com:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.1.203:5060;branch=z9hG4bK2D471D5C
Remote-Party-ID: "18452055545" <sip:17772253754@192.168.1.203>;party=calling;screen=yes;privacy=off
From: "18452055545" <sip:17772253754@callcentric.com>;tag=26C05560-C33
To: <sip:18165297500@callcentric.com>
Date: Mon, 24 Feb 2014 06:44:00 GMT
Call-ID: E09CD00A-9C5511E3-861AE4C3-DC5CB4B2@192.168.1.203
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE:  1800
Cisco-Guid: 0373662208-0000065536-0000000057-3355551936
User-Agent: Cisco-SIPGateway/IOS-12.x
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Timestamp: 1393224240
Contact: <sip:17772253754@192.168.1.203:5060>
Expires: 180
Allow-Events: telephone-event
Max-Forwards: 69
Session-Expires:  1800
Content-Type: application/sdp
Content-Disposition: session;handling=required
Content-Length: 309
v=0
o=CiscoSystemsSIP-GW-UserAgent 3140 3337 IN IP4 192.168.1.203
s=SIP Call
c=IN IP4 192.168.1.203
t=0 0
m=audio 16618 RTP/AVP 18 0 8 101
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=rtpmap:0 PCMU/8000
a=rtpmap:8 PCMA/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
SO - I put together the following based on my adventures with Callcentric's Inbound DID Dialing.. Thoughts? I'll grab some debugs at home tonight.
voice class sip-profiles 3
request INVITE peer-header sip Remote-Party-ID copy "(.*)" u02
request INVITE sip-header SIP-Req-URI modify ".*@(.*)" "INVITE sip:\u02@\1"
voice class sip-copylist 2
sip-header Remote-Party-ID
dial-peer voice 2 voip
description from cucm publisher
translation-profile outgoing STRIP9
session protocol sipv2
session target sip-server
incoming called-number 91[2-9]..[2-9]......
voice-class codec 1
voice-class sip copy-list 2
dtmf-relay rtp-nte
dial-peer voice 100 voip
description outgoing SIP Trunk
translation-profile outgoing Outgoing
destination-pattern 1[2-9]..[2-9]......
session target dns:callcentric.com
voice-class codec 1
voice-class sip profiles 3
dtmf-relay rtp-nte
no vad
1 REPLY
Figured this out.
request INVITE peer-header sip FROM copy "sip:(.*)@" u02
request INVITE sip-header Remote-Party-ID modify "<>" "<>"
sip-header FROM
translation-profile incoming STRIP9
voice-class codec 1
dtmf-relay rtp-nte
voice-class codec 1
dtmf-relay rtp-nte
no vad
313
