02-14-2014 10:43 PM - edited 03-16-2019 09:45 PM
I have a SIP trunk from call centric that goes into my lab gear - they appear to be a good sip service due to cost but I'm having some trouble getting calls to route correctly. The call flow is Callcentric.com ITSP (SIP) --> 2811 (acting as cube) -->SIP Trunk --> CUCM 8.6. Phones are registered to CUCM.
I have the sip trunk registered and calls come in to the router (I see them in ccsip message/call debugs) The 2811 running 15.1(4)M7). Callcentric sends the username of the customer in the sip Invite instead of the called number, the called number is in the TO field. I have several DID’s from Callcentric (18452055544, 18452055545, 18452055546) for my lab. There are a few configs on here for CME where the customer number (17772253754) is simply translated to their phone DN - which is fine if you only have 1 DN with callcentric but more than 1 and thats not feasible since every inbound did will be matched to that 17772253754 translation/phone dn.
I’m using the a guide from http://tblog.cisco.be/2011/02/17/cube-conditional-sip-profiles/ using the Copy function as described http://www.cisco.com/c/en/us/products/collateral/ios-nx-os-software/ios-software-release-15-1-3-t/product_bulletin_c25-635704.html
I haven’t been able to find anything where they actually explain all the header fields so Its mostly trial and error.. so far mostly error. I think I’m close.. but who knows. Any assistance would be greatly appreciated
voice class sip-profiles 1
request INVITE peer-header sip TO copy ".sip:(.*)@." u01
request INVITE sip-header SIP-Req-URI modify ".*@(.*)" "INVITE sip:\u01@\1"
CUCM (single/pub)- 192.168.1.200
2811 acting as cube - 192.168.1.203
Calling Number - 18165297500
Called Number - 18452055544
vrtr1#show sip register status
Line peer expires(sec) registered P-Associ-URI
17772253754 -1 20 yes
vrtr1#
The Call Setup Information is:
Call Control Block (CCB) : 0x49646C28
State of The Call : STATE_DEAD
TCP Sockets Used : NO
Calling Number : 18165297500
Called Number : 17772253754 (my customer number not called number)
Source IP Address (Sig ): 192.168.1.203 (my 2811 router)
Destn SIP Req Addr:Port : 204.11.192.159:5080
Destn SIP Resp Addr:Port : 204.11.192.159:5080
Destination Name : 204.11.192.159
Feb 14 11:20:53.303: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:17772253754@192.168.1.203:5060 SIP/2.0
v: SIP/2.0/UDP 204.11.192.159:5080;branch=z9hG4bK-805ff2443b18502ff96181045b62dd74
f: <sip:18165297500@66.193.176.35>;tag=3601387252-874282
t: <sip:18452055544@ss.callcentric.com>
i: 2917398-3601387252-874253@msw2.telengy.net
CSeq: 1 INVITE
Max-Forwards: 8
m: <sip:ca7fe50c9cebe12327fe0d63c5962a3e@204.11.192.159:5080;transport=udp>
Supported: timer
c: application/sdp
l: 350
v=0
o=NexTone-MSW 2147483647 2147483647 IN IP4 204.11.192.159
s=sip call
c=IN IP4 204.11.192.159
t=0 0
m=audio 61094 RTP/AVP 18 0 8 101
a=fmtp:18 annexb=no
a=fmtp:101 0-15
a=rtpmap:101 telephone-event/8000
a=rtpmap:8 PCMA/8000
a=rtpmap:0 PCMU/8000
a=rtpmap:18 G729/8000
a=ptime:20
a=sendrecv
a=silenceSupp:off - - - -
a=setup:actpass
Feb 14 11:20:53.327: //936/310B294680AD/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 204.11.192.159:5080;branch=z9hG4bK-805ff2443b18502ff96181045b62dd74
From: <sip:18165297500@66.193.176.35>;tag=3601387252-874282
To: <sip:18452055544@ss.callcentric.com>
Date: Fri, 14 Feb 2014 17:20:53 GMT
Call-ID: 2917398-3601387252-874253@msw2.telengy.net
CSeq: 1 INVITE
Allow-Events: telephone-event
Server: Cisco-SIPGateway/IOS-12.x
Content-Length: 0
Sent:
SIP/2.0 404 Not Found
To: <sip:18452055544@ss.callcentric.com>;tag=35399D8-63
CSeq: 1 INVITE
Reason: Q.850;cause=1
Content-Length: 0
Feb 14 11:20:53.419: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:17772253754@192.168.1.203:5060 SIP/2.0
t: <sip:18452055544@ss.callcentric.com>;tag=35399D8-63
CSeq: 1 ACK
Max-Forwards: 10
l: 0
u all
Feb 14 11:20:57.067: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:18452055544;cic=0288;rn=6465471001;npdi@alpha14.callcentric.com:5070 SIP/2.0
v: SIP/2.0/UDP 204.11.192.159:5080;branch=z9hG4bK-6bceae47efe9f53b4234698a32ac8beb
CSeq: 1 ACK
Max-Forwards: 8
l: 0
************************** Running Config **************************
sh run
vrtr1#sh running-config
Building configuration...
Current configuration : 4189 bytes
! Last configuration change at 00:34:03 CST Fri Feb 14 2014
! NVRAM config last updated at 20:26:58 CST Thu Feb 13 2014
version 15.1
service timestamps debug datetime msec localtime
service timestamps log datetime msec localtime
hostname vrtr1
boot-start-marker
boot system flash:
boot system flash flash:c2800nm-ipvoicek9-mz.151-4.M7.bin
boot-end-marker
card type t1 0 0
logging buffered 4096 notifications
enable password cisco
no aaa new-model
memory-size iomem 5
clock timezone CST -6 0
clock summer-time CST recurring
no network-clock-participate wic 0
dot11 syslog
ip source-route
ip cef
ip name-server 192.168.1.9
no ipv6 cef
voice service voip
ip address trusted list
ipv4 192.168.1.0 255.255.255.0
ipv4 204.11.192.0 255.255.255.0
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
sip
bind control source-interface FastEthernet0/0
bind media source-interface FastEthernet0/0
registrar server expires max 1800 min 1800
localhost dns:callcentric.com
outbound-proxy dns:callcentric.com
voice class codec 1
codec preference 1 g729r8
codec preference 2 g711ulaw
voice-card 0
license udi pid CISCO2811 sn FTX1133A4QR
controller T1 0/0/0
cablelength long 0db
description ** LAN **
ip address 192.168.1.203 255.255.255.0
duplex auto
speed auto
h323-gateway voip interface
h323-gateway voip bind srcaddr 192.168.1.203
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 192.168.1.1
snmp mib persist circuit
control-plane
voice-port 0/1/0
voice-port 0/1/1
voice-port 0/1/2
voice-port 0/1/3
ccm-manager mgcp
no ccm-manager fax protocol cisco
ccm-manager music-on-hold
ccm-manager config server 192.168.1.200
ccm-manager config
mgcp
mgcp call-agent 192.168.1.200 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
no mgcp package-capability res-package
no mgcp package-capability fxr-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 inhibit
mgcp rtp payload-type g726r16 static
mgcp bind control source-interface FastEthernet0/0
mgcp bind media source-interface FastEthernet0/0
mgcp profile default
dial-peer voice 999100 pots
service mgcpapp
port 0/1/0
dial-peer voice 999101 pots
service mgcpapp
port 0/1/1
dial-peer voice 999102 pots
service mgcpapp
port 0/1/2
dial-peer voice 999103 pots
service mgcpapp
port 0/1/3
dial-peer voice 999010 pots
service mgcpapp
port 0/1/0
dial-peer voice 6 voip
description ## INBOUND DID to CUCM ##
session protocol sipv2
session target ipv4:192.168.1.200
incoming called-number 17772253754
voice-class sip profiles 1
dtmf-relay h245-alphanumeric
no vad
dial-peer voice 7 voip
incoming called-number 1845205554[4-5]
no vad
sip-ua
credentials username 17772253754 password 7 106C1B49111F17194D realm callcentric.com
authentication username 17772253754 password 7 08035E1E1D11000553 realm callcentric.com
no remote-party-id
retry invite 2
retry register 10
timers connect 100
mwi-server dns:callcentric.com expires 3600 port 5060 transport udp
registrar dns:callcentric.com expires 3600
sip-server dns:callcentric.com
host-registrar
line con 0
line aux 0
line vty 0 4
password cisco
login
transport input all
scheduler allocate 20000 1000
ntp server 199.102.46.72
ntp server 23.227.162.123 prefer
end
exit
Solved! Go to Solution.
02-20-2014 04:26 PM
Carlo, thank you my friend for the kind words..
There were three major issues...
1. sip outbound-proxy issue where all calls orginating from the CUBE was sent back to the provider even though the sip headers looked like they were sent to CUCM..You can read the analysis of that on the thread with this time stamp
16-Feb-2014 15:02 (in response to whatuusay1)
2. The ITSP didnt specify session timer, hence CUBE was sending a Require header in the 200 OK and they didnt like it. So I removed the Require header in the 200 Ok response:
response 200 sip-header Require remove
3. The third issue was routing calls based on the To header. The ITSP was sending the called number in the To header and the authentication DDI in the RURI..This was rather complicated due to the voice translation rules messing up the sip profiles.. You can see the solution on this time stamp..
20-Feb-2014 21:06 (in response to Ayodeji oladipo Okanlawon)
The following sip profiles were used..
request INVITE peer-header sip TO copy "sip:(.*)@" u01
voice class sip-copylist 1
sip-header TO
Please rate all useful posts
"The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
02-14-2014 11:20 PM
Whatever i can see from CUBE config , you are sending called number 17772253754 to CUCM but CUBE did not invoked second call leg i.e. from CUBE to CUCM.
Can you try by applying these changes...
description ## INBOUND CALL from ITSP ##
no vad
dial-peer voice XXX voip
destination-pattern 17772253754
no vad
And then send across "debug ccsip message" from the cube.
Manish
02-15-2014 12:22 AM
Hi.
In addition to what correctly suggested by Manish (+5), please modify dtmf mode on sip dialpeers to rtp-nte.
Carlo
Please rate all helpful posts
"The more you help the more you learn"
02-15-2014 08:21 AM
Thank you for the reply. I've updated the dial-peers as sugested. I'm now seeing an invite go out to my CUCM however the call fails with a 403 (forbidden) which appears to come from the ITSP (Callcentric). I've included a new set of ccsip message debugs and the dial-peers as adjusted. Please let me know what you think.
session target sip-server
dtmf-relay rtp-nte
no vad
dial-peer voice 100 voip
dtmf-relay rtp-nte
no vad
dtmf-relay rtp-nte
no vad
Feb 15 10:18:11.424: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
v: SIP/2.0/UDP 204.11.192.164:5080;branch=z9hG4bK-d78945b444598bc22c8509d069f4789d
f: <18165297500>;tag=3601469891-655
t: <>>18452055544@ss.callcentric.com>
i: 3184639-3601469891-623@msw2.telengy.net
CSeq: 1 INVITE
Max-Forwards: 8
m: <0778BAA027205CDCA5AED80C59F25866>
Supported: timer
c: application/sdp
l: 3500778BAA027205CDCA5AED80C59F25866>18165297500>
v=0
o=NexTone-MSW 2147483647 2147483647 IN IP4 204.11.192.164
s=sip call
c=IN IP4 204.11.192.164
t=0 0
m=audio 61782 RTP/AVP 18 0 8 101
a=fmtp:18 annexb=no
a=fmtp:101 0-15
a=ptime:20
a=sendrecv
a=setup:actpass
Feb 15 10:18:11.456: //2419/9933162D820E/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 204.11.192.164:5080;branch=z9hG4bK-d78945b444598bc22c8509d069f4789d
To: <>>18452055544@ss.callcentric.com>
Date: Sat, 15 Feb 2014 16:18:11 GMT
Call-ID: 3184639-3601469891-623@msw2.telengy.net
CSeq: 1 INVITE
Content-Length: 018165297500>
Feb 15 10:18:11.460: //2420/9933162D820E/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:@192.168.1.200:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.1.203:5060;branch=z9hG4bK9A91F35
From: <>>18165297500@callcentric.com>;tag=8408644-12C8
To: <17772253754>
Call-ID: 993622F5-959311E3-8214FFD7-951695DD@callcentric.com
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE: 1800
Cisco-Guid: 2570262061-2509443555-2182021079-2501285341
User-Agent: Cisco-SIPGateway/IOS-12.x
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Timestamp: 1392481091
Contact: <18165297500>
Expires: 180
Max-Forwards: 7
Content-Type: application/sdp
Content-Disposition: session;handling=required
Content-Length: 27318165297500>17772253754>
v=0
o=CiscoSystemsSIP-GW-UserAgent 2786 1511 IN IP4 192.168.1.203
s=SIP Call
c=IN IP4 192.168.1.203
t=0 0
m=audio 18168 RTP/AVP 18 101
a=fmtp:18 annexb=no
a=fmtp:101 0-15
a=ptime:20
Feb 15 10:18:11.552: //2420/9933162D820E/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 407 Proxy Authentication Required
v: SIP/2.0/UDP 192.168.1.203:5060;branch=z9hG4bK9A91F35;rport=57100;received=24.123.98.94
f: <>>18165297500@callcentric.com>;tag=8408644-12C8
t: <17772253754>
i: 993622F5-959311E3-8214FFD7-951695DD@callcentric.com
CSeq: 101 INVITE
Proxy-Authenticate: Digest realm="callcentric.com", domain="sip:callcentric.com", nonce="8ae6b7b1cea74cf401e8a26fd3c7371b", opaque="", stale=TRUE, algorithm=MD5
l: 017772253754>
Feb 15 10:18:11.560: //2420/9933162D820E/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:17772253754@192.168.1.200:5060 SIP/2.0
To: <17772253754>
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 017772253754>
Sent:
Via: SIP/2.0/UDP 192.168.1.203:5060;branch=z9hG4bK9AA1BA3
To: <17772253754>
Min-SE: 1800
CSeq: 102 INVITE
Expires: 180
Proxy-Authorization: Digest username="17772253754",realm="callcentric.com",uri="sip:17772253754@192.168.1.200:5060",response="a381f10fbbfbd255b444569fef0dddfe",nonce="8ae6b7b1cea74cf401e8a26fd3c7371b",opaque="",algorithm=MD5
Max-Forwards: 7
v=0
s=SIP Call
t=0 0
a=fmtp:18 annexb=no
a=fmtp:101 0-15
a=ptime:20
Feb 15 10:18:11.648: //2420/9933162D820E/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 403 Incorrect Authentication
v: SIP/2.0/UDP 192.168.1.203:5060;branch=z9hG4bK9AA1BA3;rport=57100;received=24.123.98.94
t: <17772253754>
CSeq: 102 INVITE
l: 017772253754>
Feb 15 10:18:11.660: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
To: <17772253754>
Max-Forwards: 70
CSeq: 102 ACK
Feb 15 10:18:11.660: //2419/9933162D820E/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 403 Forbidden
To: <>>18452055544@ss.callcentric.com>;tag=8408714-B60
CSeq: 1 INVITE
Reason: Q.850;cause=57
Feb 15 10:18:11.752: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
apsc-vrtr1#ACK sip:17772253754@192.168.1.203:5060 SIP/2.0
t: <>>18452055544@ss.callcentric.com>;tag=8408714-B60
CSeq: 1 ACK
Max-Forwards: 10
l: 018165297500>
vrtr1#u al
Feb 15 10:18:14.776: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:18452055544;cic=0288;rn=6465471001;npdi@alpha16.callcentric.com:5070 SIP/2.0
v: SIP/2.0/UDP 204.11.192.164:5080;branch=z9hG4bK-e437c2c5cac5f1a6e147c1cd7c98aad7
CSeq: 1 ACK
Max-Forwards: 8
l: 018165297500>
02-15-2014 08:35 AM
HI
Can you check your authentication under sip-ua?.Check the username and password under sip-ua.
SIP/2.0 403 Incorrect Authentication.
please rate all useuful information
02-15-2014 01:18 PM
THe new INVITE you are sending doesnt contain any number in the RURI..
This is the INVITE sent to CUCM
Sent:
INVITE sip:@192.168.1.200:5060 SIP/2.0 (there is no user portion in the INVITE..i.e the called number)
I suggest you remove the sip profile 1 from your dial-peer to cucm because I think its messing up your INVITE
02-15-2014 08:24 PM
Thank you - I removed the sip profile from the dial-peers as a troubleshooting step. I've attached the ccsip messages debug after doing so.
It looks like the SIP INVITE now has a number (its the username and not the actual did i called). It looks like callcentric replied with a SIP/2.0 407 Proxy Authentication Required. Not sure how to get past that..
INVITE sip:17772253754@192.168.1.200:5060 SIP/2.0
Config as configured with the ccsip message debug.
voice service voip
sip
voice class codec 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
voice-class codec 1
dtmf-relay rtp-nte
no vad
voice-class codec 1
dtmf-relay rtp-nte
no vad
sip-ua
credentials username 17772253754 password 7 047919561B29495C48 realm callcentric.com
authentication username 17772253754 password 7 106C1B49111F17195C5C realm 24.123.98.94
no remote-party-id
retry invite 4
retry response 3
retry bye 2
retry register 5
timers connect 100
mwi-server dns:callcentric.com expires 1800 port 5060 transport udp
registrar dns:callcentric.com expires 1800
sip-server dns:callcentric.com:5060
host-registrar
Feb 15 22:15:28.440: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
v: SIP/2.0/UDP 204.11.192.164:5080;branch=z9hG4bK-c0773d290cf0723fce82a45842ed1a9d
f: <18165297500>;tag=3601512928-48129
i: 3299487-3601512928-48097@msw2.telengy.net
CSeq: 1 INVITE
Max-Forwards: 8
m: <33E88838C1C1F83FE4D98EEEC68D9BA0>
Supported: timer
c: application/sdp
l: 35033E88838C1C1F83FE4D98EEEC68D9BA0>18165297500>
v=0
s=sip call
t=0 0
m=audio 63994 RTP/AVP 18 0 8 101
a=fmtp:18 annexb=no
a=fmtp:101 0-15
a=ptime:20
a=sendrecv
a=setup:actpass
Feb 15 22:15:28.456: //3192/CD429E0782C5/SIP/Msg/ccsipDisplayMsg:
Sent:
apsc-vrtr1#SIP/2.0 100 Trying
Via: SIP/2.0/UDP 204.11.192.164:5080;branch=z9hG4bK-c0773d290cf0723fce82a45842ed1a9d
Date: Sun, 16 Feb 2014 04:15:28 GMT
Call-ID: 3299487-3601512928-48097@msw2.telengy.net
CSeq: 1 INVITE
Feb 15 22:15:28.592: //3193/CD429E0782C5/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 192.168.1.203:5060;branch=z9hG4bKCC913E1
From: <>>18165297500@callcentric.com>;tag=AD13394-1090
To: <17772253754>
Call-ID: CD46E3B8-95F711E3-82CBFFD7-951695DD@callcentric.com
Min-SE: 1800
Cisco-Guid: 3443695111-2515997155-2194014167-2501285341
CSeq: 101 INVITE
Timestamp: 1392524128
Expires: 180
Max-Forwards: 7
Content-Length: 28418165297500>17772253754>
v=0
o=CiscoSystemsSIP-GW-UserAgent 2039 178 IN IP4 192.168.1.203
s=SIP Call
t=0 0
m=audio 17858 RTP/AVP 18 0 101
a=fmtp:18 annexb=no
a=fmtp:101 0-15
Feb 15 22:15:28.688: //3193/CD429E0782C5/SIP/Msg/ccsipDisplayMsg:
Received:
v: SIP/2.0/UDP 192.168.1.203:5060;branch=z9hG4bKCC913E1;rport=64232;received=24.123.98.94
f: <>>18165297500@callcentric.com>;tag=AD13394-1090
t: <17772253754>
i: CD46E3B8-95F711E3-82CBFFD7-951695DD@callcentric.com
CSeq: 101 INVITE
Proxy-Authenticate: Digest realm="callcentric.com", domain="sip:callcentric.com", nonce="a3004fd6e15e380e2387317080d640fe", opaque="", stale=TRUE, algorithm=MD5
l: 017772253754>
Feb 15 22:15:28.700: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
To: <17772253754>
Max-Forwards: 70
CSeq: 101 ACK
Feb 15 22:15:28.700: //3192/CD429E0782C5/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 503 Service Unavailable
To: <>>18452055544@ss.callcentric.com>;tag=AD13404-1D88
CSeq: 1 INVITE
Reason: Q.850;cause=47
Feb 15 22:15:28.784: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
t: <>>18452055544@ss.callcentric.com>;tag=AD13404-1D88
CSeq: 1 ACK
Max-Forwards: 10
l: 018165297500>
vrtr1#u all
All possible debugging has been turned off
02-15-2014 09:35 PM
Before we deal with the issue of the called number, lets deal with this signle call first. CUBE is sending service unavailable..Ledts deal with that first..Configure the following and attach the debug
conf t
voice class codec 1
codec preference 3 g711alaw---------------------add this
service sequence-numbers
service timestamps debug datetime localtime msec
logging buffered 10000000 debug
no logging console
no logging monitor
default logging rate-limit
default logging queue-limit
Then..
debug ccsip all
then do the ff:
terminal length 0
show logging
02-15-2014 09:47 PM
02-15-2014 09:45 PM
If i am correct 192.168.1.200 is your CUCM ip.
Here CUCM is responding with proxy authentication required message. I dont know why CUCM is asking for proxy authentication, did you added SIP trunk on your CUCM correctly ? Does any kind of authentication placed in CUCM sip trunk for Inbound calls ?
Sent:
To: <17772253754>17772253754>
Received:
t: <17772253754>17772253754>
Now CUBE is responding to that proxy authentication request with Callcentric credentials which is incorrect. The credentials for callcentric is only for the call placed or received from ITSP not towards the CUCM.
Cal you attach "debug voice dialpeer inout" for a test call.
Rate all the helpful posts.
Manish
02-15-2014 09:48 PM
Manish,
CUBE is not responding to the proxy authentication request at all...It just sent Service unavailable with cause code 47
02-15-2014 09:58 PM
Oh.Yes ..Correct....I was just referring to the second "debug ccsip message" after adding the dial-peer in which CUBE respond with callcentric credentials.
I think that has been fixed by removing sip profile from dial-peer.
Manish
02-15-2014 09:51 PM
02-15-2014 09:56 PM
Okay, the logs show that CUBE cant handle the authentication challenge cucm is sending..
Can you go to cucm and disable digest authentication on your sip security profile for the trunk...lets start from there
004483: Feb 15 23:38:10.368: //3285/5A9EFEB982E8/SIP/Error/sipSPIHandleAuthChallenge: Error getting credentials
004484: Feb 15 23:38:10.368: //3285/5A9EFEB982E8/SIP/Error/act_sentinvite_new_message: Error handling AuthenticationChallenge
004485: Feb 15 23:38:10.368: //3285/5A9EFEB982E8/SIP/State/sipSPIChangeState: 0x4963B838 : State change from (STATE_SENT_INVITE, SUBSTATE_NONE) to (STATE_DISCONNECTING, SUBSTATE_NONE)
004486: Feb 15 23:38:10.368: //3285/5A9EFEB982E8/SIP/Info/ccsip_set_cc_cause_for_spi_err: Categorized cause:47, category:181
004487: Feb 15 23:38:10.368: //3285/5A9EFEB982E8/SIP/Info/sipSPIInitiateDisconnect: Initiate call disconnect(47) for outgoing call
02-15-2014 10:06 PM
