Callcentric SIP Trunk (ITSP --> 2811 CUBE --> CUCM 8.6
I have a SIP trunk from call centric that goes into my lab gear - they appear to be a good sip service due to cost but I'm having some trouble getting calls to route correctly. The call flow is Callcentric.com ITSP (SIP) --> 2811 (acting as cube) -->SIP Trunk --> CUCM 8.6. Phones are registered to CUCM.
I have the sip trunk registered and calls come in to the router (I see them in ccsip message/call debugs) The 2811 running  15.1(4)M7). Callcentric sends the username of the customer in the sip Invite instead of the called number, the called number is in the TO field. I have several DID’s from Callcentric (18452055544, 18452055545, 18452055546) for my lab. There are a few configs on here for CME where the customer number (17772253754) is simply translated to their phone DN - which is fine if you only have 1 DN with callcentric but more than 1 and thats not feasible since every inbound did will be matched to that 17772253754 translation/phone dn.
I’m using the a guide from http://tblog.cisco.be/2011/02/17/cube-conditional-sip-profiles/ using the Copy function as described http://www.cisco.com/c/en/us/products/collateral/ios-nx-os-software/ios-software-release-15-1-3-t/product_bulletin_c25-635704.html
I haven’t been able to find anything where they actually explain all the header fields so Its mostly trial and error.. so far mostly error.  I think I’m close.. but who knows. Any assistance would be greatly appreciated
voice class sip-profiles 1
request INVITE peer-header sip TO copy ".sip:(.*)@." u01
request INVITE sip-header SIP-Req-URI modify ".*@(.*)" "INVITE sip:\u01@\1"
CUCM (single/pub)- 192.168.1.200
2811 acting as cube - 192.168.1.203
Calling Number - 18165297500
Called Number - 18452055544
vrtr1#show  sip register status
Line                             peer       expires(sec) registered P-Associ-URI
17772253754                      -1         20           yes
vrtr1#
The Call Setup Information is:
Call Control Block (CCB) : 0x49646C28
State of The Call        : STATE_DEAD
TCP Sockets Used         : NO
Calling Number           : 18165297500
Called Number            : 17772253754 (my customer number not called number)
Source IP Address (Sig  ): 192.168.1.203 (my 2811 router)
Destn SIP Req Addr:Port  : 204.11.192.159:5080
Destn SIP Resp Addr:Port : 204.11.192.159:5080
Destination Name         : 204.11.192.159
Feb 14 11:20:53.303: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:17772253754@192.168.1.203:5060 SIP/2.0
v: SIP/2.0/UDP 204.11.192.159:5080;branch=z9hG4bK-805ff2443b18502ff96181045b62dd74
f: <sip:18165297500@66.193.176.35>;tag=3601387252-874282
t: <sip:18452055544@ss.callcentric.com>
i: 2917398-3601387252-874253@msw2.telengy.net
CSeq: 1 INVITE
Max-Forwards: 8
m: <sip:ca7fe50c9cebe12327fe0d63c5962a3e@204.11.192.159:5080;transport=udp>
Supported: timer
c: application/sdp
l: 350
v=0
o=NexTone-MSW 2147483647 2147483647 IN IP4 204.11.192.159
s=sip call
c=IN IP4 204.11.192.159
t=0 0
m=audio 61094 RTP/AVP 18 0 8 101
a=fmtp:18 annexb=no
a=fmtp:101 0-15
a=rtpmap:101 telephone-event/8000
a=rtpmap:8 PCMA/8000
a=rtpmap:0 PCMU/8000
a=rtpmap:18 G729/8000
a=ptime:20
a=sendrecv
a=silenceSupp:off - - - -
a=setup:actpass
Feb 14 11:20:53.327: //936/310B294680AD/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 204.11.192.159:5080;branch=z9hG4bK-805ff2443b18502ff96181045b62dd74
From: <sip:18165297500@66.193.176.35>;tag=3601387252-874282
To: <sip:18452055544@ss.callcentric.com>
Date: Fri, 14 Feb 2014 17:20:53 GMT
Call-ID: 2917398-3601387252-874253@msw2.telengy.net
CSeq: 1 INVITE
Allow-Events: telephone-event
Server: Cisco-SIPGateway/IOS-12.x
Content-Length: 0
Sent:
SIP/2.0 404 Not Found
To: <sip:18452055544@ss.callcentric.com>;tag=35399D8-63
CSeq: 1 INVITE
Reason: Q.850;cause=1
Content-Length: 0
Feb 14 11:20:53.419: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:17772253754@192.168.1.203:5060 SIP/2.0
t: <sip:18452055544@ss.callcentric.com>;tag=35399D8-63
CSeq: 1 ACK
Max-Forwards: 10
l: 0
u all
Feb 14 11:20:57.067: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:18452055544;cic=0288;rn=6465471001;npdi@alpha14.callcentric.com:5070 SIP/2.0
v: SIP/2.0/UDP 204.11.192.159:5080;branch=z9hG4bK-6bceae47efe9f53b4234698a32ac8beb
CSeq: 1 ACK
Max-Forwards: 8
l: 0
************************** Running Config **************************
sh run
vrtr1#sh running-config
Building configuration...
Current configuration : 4189 bytes
! Last configuration change at 00:34:03 CST Fri Feb 14 2014
! NVRAM config last updated at 20:26:58 CST Thu Feb 13 2014
version 15.1
service timestamps debug datetime msec localtime
service timestamps log datetime msec localtime
hostname vrtr1
boot-start-marker
boot system flash:
boot system flash flash:c2800nm-ipvoicek9-mz.151-4.M7.bin
boot-end-marker
card type t1 0 0
logging buffered 4096 notifications
enable password cisco
no aaa new-model
memory-size iomem 5
clock timezone CST -6 0
clock summer-time CST recurring
no network-clock-participate wic 0
dot11 syslog
ip source-route
ip cef
ip name-server 192.168.1.9
no ipv6 cef
voice service voip
ip address trusted list
  ipv4 192.168.1.0 255.255.255.0
  ipv4 204.11.192.0 255.255.255.0
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
sip
  bind control source-interface FastEthernet0/0
  bind media source-interface FastEthernet0/0
  registrar server expires max 1800 min 1800
  localhost dns:callcentric.com
  outbound-proxy dns:callcentric.com
voice class codec 1
codec preference 1 g729r8
codec preference 2 g711ulaw
voice-card 0
license udi pid CISCO2811 sn FTX1133A4QR
controller T1 0/0/0
cablelength long 0db
description ** LAN **
ip address 192.168.1.203 255.255.255.0
duplex auto
speed auto
h323-gateway voip interface
h323-gateway voip bind srcaddr 192.168.1.203
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 192.168.1.1
snmp mib persist circuit
control-plane
voice-port 0/1/0
voice-port 0/1/1
voice-port 0/1/2
voice-port 0/1/3
ccm-manager mgcp
no ccm-manager fax protocol cisco
ccm-manager music-on-hold
ccm-manager config server 192.168.1.200
ccm-manager config
mgcp
mgcp call-agent 192.168.1.200 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
no mgcp package-capability res-package
no mgcp package-capability fxr-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 inhibit
mgcp rtp payload-type g726r16 static
mgcp bind control source-interface FastEthernet0/0
mgcp bind media source-interface FastEthernet0/0
mgcp profile default
dial-peer voice 999100 pots
service mgcpapp
port 0/1/0
dial-peer voice 999101 pots
service mgcpapp
port 0/1/1
dial-peer voice 999102 pots
service mgcpapp
port 0/1/2
dial-peer voice 999103 pots
service mgcpapp
port 0/1/3
dial-peer voice 999010 pots
service mgcpapp
port 0/1/0
dial-peer voice 6 voip
description ## INBOUND DID to CUCM ##
session protocol sipv2
session target ipv4:192.168.1.200
incoming called-number 17772253754
voice-class sip profiles 1
dtmf-relay h245-alphanumeric
no vad
dial-peer voice 7 voip
incoming called-number 1845205554[4-5]
no vad
sip-ua
credentials username 17772253754 password 7 106C1B49111F17194D realm callcentric.com
authentication username 17772253754 password 7 08035E1E1D11000553 realm callcentric.com
no remote-party-id
retry invite 2
retry register 10
timers connect 100
mwi-server dns:callcentric.com expires 3600 port 5060 transport udp
registrar dns:callcentric.com expires 3600
sip-server dns:callcentric.com
host-registrar
line con 0
line aux 0
line vty 0 4
password cisco
login
transport input all
scheduler allocate 20000 1000
ntp server 199.102.46.72
ntp server 23.227.162.123 prefer
end
exit
Everyone's tags (4)
1 ACCEPTED SOLUTION
VIP Super Bronze
Carlo, thank you my friend for the kind words..
There were three major issues...
1. sip outbound-proxy issue where all calls orginating from the CUBE was sent back to the provider even though the sip headers looked like they were sent to CUCM..You can read the analysis of that on the thread with this time stamp
16-Feb-2014 15:02                             (in response to whatuusay1)
2. The ITSP didnt specify session timer, hence CUBE was sending a Require header in the 200 OK and they didnt like it. So I removed the Require header in the 200 Ok response:
response 200 sip-header Require remove
3. The third issue was routing calls based on the To header. The ITSP was sending the called number in the To header and the authentication DDI in the RURI..This was rather complicated due to the voice translation rules messing up the sip profiles.. You can see the solution on this time stamp..
20-Feb-2014 21:06                             (in response to Ayodeji oladipo Okanlawon)
The following sip profiles were used..
request INVITE peer-header sip TO copy "sip:(.*)@" u01
voice class sip-copylist 1
sip-header TO
Please rate all useful posts
"The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
Re: Callcentric SIP Trunk (ITSP --> 2811 CUBE --> CUCM 8.6
Whatever i can see from CUBE config , you are sending called number 17772253754 to CUCM but CUBE did not invoked second call leg  i.e. from CUBE to CUCM.
Can you try by applying these changes...
description ## INBOUND CALL from ITSP ##
no vad
dial-peer voice XXX voip
destination-pattern 17772253754
no vad
And then send across "debug ccsip message" from the cube.
Manish
Hi.
In addition to what correctly suggested by Manish (+5), please modify dtmf mode on sip dialpeers to rtp-nte.
Carlo
Please rate all helpful posts
"The more you help the more you learn"
Please rate all helpful posts "The more you help the more you learn"
Thank you for the reply. I've updated the dial-peers as sugested. I'm now seeing an invite go out to my CUCM however the call fails with a 403 (forbidden) which appears to come from the ITSP (Callcentric). I've included a new set of ccsip message debugs and the dial-peers as adjusted. Please let me know what you think.
session target sip-server
dtmf-relay rtp-nte
no vad
dial-peer voice 100 voip
dtmf-relay rtp-nte
no vad
dtmf-relay rtp-nte
no vad
Feb 15 10:18:11.424: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
v: SIP/2.0/UDP 204.11.192.164:5080;branch=z9hG4bK-d78945b444598bc22c8509d069f4789d
f: <18165297500>;tag=3601469891-655
t: <>18452055544@ss.callcentric.com>
i: 3184639-3601469891-623@msw2.telengy.net
CSeq: 1 INVITE
Max-Forwards: 8
m: <0778BAA027205CDCA5AED80C59F25866>
Supported: timer
c: application/sdp
l: 350
v=0
o=NexTone-MSW 2147483647 2147483647 IN IP4 204.11.192.164
s=sip call
c=IN IP4 204.11.192.164
t=0 0
m=audio 61782 RTP/AVP 18 0 8 101
a=fmtp:18 annexb=no
a=fmtp:101 0-15
a=ptime:20
a=sendrecv
a=setup:actpass
Feb 15 10:18:11.456: //2419/9933162D820E/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 204.11.192.164:5080;branch=z9hG4bK-d78945b444598bc22c8509d069f4789d
To: <>18452055544@ss.callcentric.com>
Date: Sat, 15 Feb 2014 16:18:11 GMT
Call-ID: 3184639-3601469891-623@msw2.telengy.net
CSeq: 1 INVITE
Content-Length: 0
Feb 15 10:18:11.460: //2420/9933162D820E/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:@192.168.1.200:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.1.203:5060;branch=z9hG4bK9A91F35
From: <>18165297500@callcentric.com>;tag=8408644-12C8
To: <17772253754>
Call-ID: 993622F5-959311E3-8214FFD7-951695DD@callcentric.com
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE:  1800
Cisco-Guid: 2570262061-2509443555-2182021079-2501285341
User-Agent: Cisco-SIPGateway/IOS-12.x
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Timestamp: 1392481091
Contact: <18165297500>
Expires: 180
Max-Forwards: 7
Content-Type: application/sdp
Content-Disposition: session;handling=required
Content-Length: 273
v=0
o=CiscoSystemsSIP-GW-UserAgent 2786 1511 IN IP4 192.168.1.203
s=SIP Call
c=IN IP4 192.168.1.203
t=0 0
m=audio 18168 RTP/AVP 18 101
a=fmtp:18 annexb=no
a=fmtp:101 0-15
a=ptime:20
Feb 15 10:18:11.552: //2420/9933162D820E/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 407 Proxy Authentication Required
v: SIP/2.0/UDP 192.168.1.203:5060;branch=z9hG4bK9A91F35;rport=57100;received=24.123.98.94
f: <>18165297500@callcentric.com>;tag=8408644-12C8
t: <17772253754>
i: 993622F5-959311E3-8214FFD7-951695DD@callcentric.com
CSeq: 101 INVITE
Proxy-Authenticate: Digest realm="callcentric.com", domain="sip:callcentric.com", nonce="8ae6b7b1cea74cf401e8a26fd3c7371b", opaque="", stale=TRUE, algorithm=MD5
l: 0
Feb 15 10:18:11.560: //2420/9933162D820E/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:17772253754@192.168.1.200:5060 SIP/2.0
To: <17772253754>
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Sent:
Via: SIP/2.0/UDP 192.168.1.203:5060;branch=z9hG4bK9AA1BA3
To: <17772253754>
Min-SE:  1800
CSeq: 102 INVITE
Expires: 180
Proxy-Authorization: Digest username="17772253754",realm="callcentric.com",uri="sip:17772253754@192.168.1.200:5060",response="a381f10fbbfbd255b444569fef0dddfe",nonce="8ae6b7b1cea74cf401e8a26fd3c7371b",opaque="",algorithm=MD5
Max-Forwards: 7
Content-Length: 273
v=0
s=SIP Call
t=0 0
a=fmtp:18 annexb=no
a=fmtp:101 0-15
a=ptime:20
Feb 15 10:18:11.648: //2420/9933162D820E/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 403 Incorrect Authentication
v: SIP/2.0/UDP 192.168.1.203:5060;branch=z9hG4bK9AA1BA3;rport=57100;received=24.123.98.94
t: <17772253754>
CSeq: 102 INVITE
l: 0
Feb 15 10:18:11.660: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
To: <17772253754>
Max-Forwards: 70
CSeq: 102 ACK
Content-Length: 0
Feb 15 10:18:11.660: //2419/9933162D820E/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 403 Forbidden
To: <>18452055544@ss.callcentric.com>;tag=8408714-B60
CSeq: 1 INVITE
Reason: Q.850;cause=57
Content-Length: 0
Feb 15 10:18:11.752: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
apsc-vrtr1#ACK sip:17772253754@192.168.1.203:5060 SIP/2.0
t: <>18452055544@ss.callcentric.com>;tag=8408714-B60
CSeq: 1 ACK
Max-Forwards: 10
l: 0
vrtr1#u al
Feb 15 10:18:14.776: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:18452055544;cic=0288;rn=6465471001;npdi@alpha16.callcentric.com:5070 SIP/2.0
v: SIP/2.0/UDP 204.11.192.164:5080;branch=z9hG4bK-e437c2c5cac5f1a6e147c1cd7c98aad7
CSeq: 1 ACK
Max-Forwards: 8
l: 0
HI
Can you check your authentication under sip-ua?.Check the username and password under sip-ua.
SIP/2.0 403 Incorrect Authentication.
please rate all useuful information
VIP Super Bronze
THe new INVITE you are sending doesnt contain any number in the RURI..
This is the INVITE sent to CUCM
Sent:
INVITE sip:@192.168.1.200:5060 SIP/2.0 (there is no user portion in the INVITE..i.e the called number)
I suggest you remove the sip profile 1 from your dial-peer to cucm because I think its messing up your INVITE
Thank you - I removed the sip profile from the dial-peers as a troubleshooting step. I've attached the ccsip messages debug after doing so.
It looks like the SIP INVITE now has a number (its the username and not the actual did i called). It looks like callcentric replied with a SIP/2.0 407 Proxy Authentication Required. Not sure how to get past that..
INVITE sip:17772253754@192.168.1.200:5060 SIP/2.0
Config as configured with the ccsip message debug.
voice service voip
sip
voice class codec 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
voice-class codec 1
dtmf-relay rtp-nte
no vad
voice-class codec 1
dtmf-relay rtp-nte
no vad
sip-ua
credentials username 17772253754 password 7 047919561B29495C48 realm callcentric.com
authentication username 17772253754 password 7 106C1B49111F17195C5C realm 24.123.98.94
no remote-party-id
retry invite 4
retry response 3
retry bye 2
retry register 5
timers connect 100
mwi-server dns:callcentric.com expires 1800 port 5060 transport udp
registrar dns:callcentric.com expires 1800
sip-server dns:callcentric.com:5060
host-registrar
Feb 15 22:15:28.440: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
v: SIP/2.0/UDP 204.11.192.164:5080;branch=z9hG4bK-c0773d290cf0723fce82a45842ed1a9d
f: <18165297500>;tag=3601512928-48129
i: 3299487-3601512928-48097@msw2.telengy.net
CSeq: 1 INVITE
Max-Forwards: 8
m: <33E88838C1C1F83FE4D98EEEC68D9BA0>
Supported: timer
c: application/sdp
l: 350
v=0
s=sip call
t=0 0
m=audio 63994 RTP/AVP 18 0 8 101
a=fmtp:18 annexb=no
a=fmtp:101 0-15
a=ptime:20
a=sendrecv
a=setup:actpass
Feb 15 22:15:28.456: //3192/CD429E0782C5/SIP/Msg/ccsipDisplayMsg:
Sent:
apsc-vrtr1#SIP/2.0 100 Trying
Via: SIP/2.0/UDP 204.11.192.164:5080;branch=z9hG4bK-c0773d290cf0723fce82a45842ed1a9d
Date: Sun, 16 Feb 2014 04:15:28 GMT
Call-ID: 3299487-3601512928-48097@msw2.telengy.net
CSeq: 1 INVITE
Content-Length: 0
Feb 15 22:15:28.592: //3193/CD429E0782C5/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 192.168.1.203:5060;branch=z9hG4bKCC913E1
From: <>18165297500@callcentric.com>;tag=AD13394-1090
To: <17772253754>
Call-ID: CD46E3B8-95F711E3-82CBFFD7-951695DD@callcentric.com
Min-SE:  1800
Cisco-Guid: 3443695111-2515997155-2194014167-2501285341
CSeq: 101 INVITE
Timestamp: 1392524128
Expires: 180
Max-Forwards: 7
Content-Length: 284
v=0
o=CiscoSystemsSIP-GW-UserAgent 2039 178 IN IP4 192.168.1.203
s=SIP Call
t=0 0
m=audio 17858 RTP/AVP 18 0 101
a=fmtp:18 annexb=no
a=fmtp:101 0-15
Feb 15 22:15:28.688: //3193/CD429E0782C5/SIP/Msg/ccsipDisplayMsg:
Received:
v: SIP/2.0/UDP 192.168.1.203:5060;branch=z9hG4bKCC913E1;rport=64232;received=24.123.98.94
f: <>18165297500@callcentric.com>;tag=AD13394-1090
t: <17772253754>
i: CD46E3B8-95F711E3-82CBFFD7-951695DD@callcentric.com
CSeq: 101 INVITE
Proxy-Authenticate: Digest realm="callcentric.com", domain="sip:callcentric.com", nonce="a3004fd6e15e380e2387317080d640fe", opaque="", stale=TRUE, algorithm=MD5
l: 0
Feb 15 22:15:28.700: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
To: <17772253754>
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Feb 15 22:15:28.700: //3192/CD429E0782C5/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 503 Service Unavailable
To: <>18452055544@ss.callcentric.com>;tag=AD13404-1D88
CSeq: 1 INVITE
Reason: Q.850;cause=47
Content-Length: 0
Feb 15 22:15:28.784: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
t: <>18452055544@ss.callcentric.com>;tag=AD13404-1D88
CSeq: 1 ACK
Max-Forwards: 10
l: 0
vrtr1#u all
All possible debugging has been turned off
VIP Super Bronze
Before we deal with the issue of the called number, lets deal with this signle call first. CUBE is sending service unavailable..Ledts deal with that first..Configure the following and attach the debug
conf t
voice class codec 1
codec preference 3 g711alaw---------------------add this
service sequence-numbers
service timestamps debug datetime localtime msec
logging buffered 10000000 debug
no logging console
no logging monitor
default logging rate-limit
default logging queue-limit
Then..
debug ccsip all
(such as Putty)
then do the ff:
terminal length 0
show logging
Thank you - I've attached the requested ccsip all debugs.
If i am correct 192.168.1.200 is your CUCM ip.
Here CUCM is responding with proxy authentication required message. I dont know why CUCM is asking for proxy authentication, did you added SIP trunk on your CUCM correctly ?  Does any kind of authentication placed in CUCM sip trunk for Inbound calls ?
Sent:
To: <17772253754>
Received:
t: <17772253754>
Now CUBE is responding to that proxy authentication request with Callcentric credentials which is incorrect. The credentials for callcentric is only for the call placed or received from ITSP not towards the CUCM.
Cal you attach "debug voice dialpeer inout" for a test call.
Rate all the helpful posts.
Manish
VIP Super Bronze
Manish,
CUBE is not responding to the proxy authentication request at all...It just sent Service unavailable with cause code 47
Oh.Yes ..Correct....I was just referring to the second "debug ccsip message" after adding the dial-peer in which CUBE respond with callcentric credentials.
I think that has been fixed by removing sip profile from dial-peer.
Manish
I've attached the dial-peer debugs as requested - more information if nothing else.
Thank you,
Andrew
VIP Super Bronze
Okay, the logs show that CUBE cant handle the authentication challenge cucm is sending..
Can you go to cucm and disable digest authentication on your sip security profile for the trunk...lets start from there
004483: Feb 15 23:38:10.368: //3285/5A9EFEB982E8/SIP/Error/sipSPIHandleAuthChallenge: Error getting credentials
004484: Feb 15 23:38:10.368: //3285/5A9EFEB982E8/SIP/Error/act_sentinvite_new_message: Error handling AuthenticationChallenge
004485: Feb 15 23:38:10.368: //3285/5A9EFEB982E8/SIP/State/sipSPIChangeState: 0x4963B838 : State change from (STATE_SENT_INVITE, SUBSTATE_NONE)  to (STATE_DISCONNECTING, SUBSTATE_NONE)
004486: Feb 15 23:38:10.368: //3285/5A9EFEB982E8/SIP/Info/ccsip_set_cc_cause_for_spi_err: Categorized cause:47, category:181
004487: Feb 15 23:38:10.368: //3285/5A9EFEB982E8/SIP/Info/sipSPIInitiateDisconnect: Initiate call disconnect(47) for outgoing call
I checked the default Non Secure SIP Trunk Profile and
Thank you,
Andrew
Here are the sip profile screenshots.
Thank you,
Andrew
Can you reset SIP trunk once and then test a call.
Manish
I reset the trunk and retested (same failure) - I've attached another set of ccsip all debugs (post sip trunk reset).
Thank you,
Andrew
Received:
v: SIP/2.0/UDP 192.168.1.203:5060;branch=z9hG4bKD58157A;rport=49552;received=24.123.98.94
Can you also remove session target sip-server from dial-peer 6.
Manish
VIP Super Bronze
I have taken some time to look in detail into the logs and here is my summary...
When you configure ooutbound-proxy dns:callcentric.com, all outbound SIP request is sent to that domain (call centric.com)
you need to remove the command "outbound-proxy dns:callcentric.com"
the summary below  explain why
++receive INVITE from ITSP+++
Received:
v: SIP/2.0/UDP 204.11.192.159:5080;branch=z9hG4bK-11f85db5478eab1a1d6560665917bdc9
f: <18165297500>;tag=3601520592-546043
i: 3308051-3601520592-546012@msw2.telengy.net
+++Next CUBE sends a trying to ITSP..Before it does that it needs to establish a TCP connection+++
NB: CUBE has sent the call back to ITSP on port 5080, because thats the port used for the incoming connection+++
008382: Feb 16 00:23:12.949: //3342/A5A3315A8319/SIP/Transport/sipTransportLogicSendMsg: Trying to send resp=0x49E83E84 to default port=5080
008383: Feb 16 00:23:12.949: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:204.11.192.159, rport:5080 with laddr:192.168.1.203
Sent:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 204.11.192.159:5080;branch=z9hG4bK-11f85db5478eab1a1d6560665917bdc9
+++Next CUBE needs to send an INVITE out to CUCM+++
NB: The target host and the outbound Host are different...The target host is who the call is for, the outbound host is who the call should be sent through+++
08432: Feb 16 00:23:12.965: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetOutboundHostAndDestHostPrivate: CCSIP: target_host : 192.168.1.200 target_port : 5060
008433: Feb 16 00:23:12.965: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetOutboundHostAndDestHostPrivate: CCSIP: outbound_host : callcentric.com outbound_port : 5060
++++Because your outbound_host is a dns entry, cube needs to resolve the DNS for the domain+++
008547: Feb 16 00:23:12.981: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_DNS_RESOLVE
008548: Feb 16 00:23:12.981: //3343/A5A3315A8319/SIP/State/sipSPIChangeState: 0x49630448 : State change from (STATE_IDLE, SUBSTATE_NONE)  to (STATE_IDLE, SUBSTATE_SENT_DNS)
+++CUBE does a SRV DNS query (looks like your DNS is configured for SRV++++++++++++
008554: Feb 16 00:23:12.985: //-1/xxxxxxxxxxxx/SIP/Info/sip_dns_type_srv_query: TYPE SRV query for _sip._udp.callcentric.com and type:1
++++Next DNS server returns all the SRV records for _sip._udp.callcentric.com++++++++
008555: Feb 16 00:23:13.057: //-1/xxxxxxxxxxxx/SIP/Info/sip_dns_type_srv_query: Server Name alpha18.callcentric.com
008556: Feb 16 00:23:13.057: //-1/xxxxxxxxxxxx/SIP/Info/sip_dns_type_srv_query: Priority 20 Weight 0 Port 5080
008557: Feb 16 00:23:13.057: //-1/xxxxxxxxxxxx/SIP/Info/sip_dns_type_srv_query: Server Name alpha19.callcentric.com
008558: Feb 16 00:23:13.057: //-1/xxxxxxxxxxxx/SIP/Info/sip_dns_type_srv_query: Priority 20 Weight 0 Port 5080
008559: Feb 16 00:23:13.061: //-1/xxxxxxxxxxxx/SIP/Info/sip_dns_type_srv_query: Server Name alpha11.callcentric.com
008560: Feb 16 00:23:13.061: //-1/xxxxxxxxxxxx/SIP/Info/sip_dns_type_srv_query: Priority 20 Weight 0 Port 5080
008561: Feb 16 00:23:13.061: //-1/xxxxxxxxxxxx/SIP/Info/sip_dns_type_srv_query: Server Name alpha12.callcentric.com
008562: Feb 16 00:23:13.061: //-1/xxxxxxxxxxxx/SIP/Info/sip_dns_type_srv_query: Priority 20 Weight 0 Port 5080
008563: Feb 16 00:23:13.061: //-1/xxxxxxxxxxxx/SIP/Info/sip_dns_type_srv_query: Server Name alpha15.callcentric.com
008564: Feb 16 00:23:13.061: //-1/xxxxxxxxxxxx/SIP/Info/sip_dns_type_srv_query: Priority 20 Weight 0 Port 5080
008565: Feb 16 00:23:13.061: //-1/xxxxxxxxxxxx/SIP/Info/sip_dns_type_srv_query: Server Name alpha16.callcentric.com
008566: Feb 16 00:23:13.061: //-1/xxxxxxxxxxxx/SIP/Info/sip_dns_type_srv_query: Priority 20 Weight 0 Port 5080
008567: Feb 16 00:23:13.061: //-1/xxxxxxxxxxxx/SIP/Info/sip_dns_type_srv_query: Server Name alpha17.callcentric.com
008568: Feb 16 00:23:13.061: //-1/xxxxxxxxxxxx/SIP/Info/sip_dns_type_srv_query: Priority 20 Weight 0 Port 5080
008569: Feb 16 00:23:13.061: //-1/xxxxxxxxxxxx/SIP/Info/sip_dns_type_srv_query: Selected Server is alpha18.callcentric.com
008570: Feb 16 00:23:13.061: //-1/xxxxxxxxxxxx/SIP/Info/sip_dns_type_a_query: TYPE A query successful for alpha18.callcentric.com
008571: Feb 16 00:23:13.061: //-1/xxxxxxxxxxxx/SIP/Info/sip_dns_type_a_query: ttl for A records = 263 seconds
+++Next DNS sends the ip address for the chosen device..204.11.192.170 (alpha18.callcentric.com)++
008572: Feb 16 00:23:13.061: //-1/xxxxxxxxxxxx/SIP/Info/sip_dns_type_srv_query: IP Address of alpha18.callcentric.com is:
008573: Feb 16 00:23:13.061: //-1/xxxxxxxxxxxx/SIP/Info/sip_dns_type_srv_query: 204.11.192.170
+++NEXT CUBE sends a UDP connection to 204.11.192.170++++++++++
008620: Feb 16 00:23:13.077: //3343/A5A3315A8319/SIP/Transport/sipSPISendInvite: Sending Invite to the transport layer
008622: Feb 16 00:23:13.077: //3343/A5A3315A8319/SIP/Transport/sipSPITransportSendMessage: msg=0x4A9AEC54, addr=204.11.192.170, port=5080, sentBy_port=0, local_addr=192.168.1.203
008626: Feb 16 00:23:13.077: //-1/xxxxxxxxxxxx/SIP/Transport/sipCreateConnHolder: Created new holder=0x4A9B0760, addr=204.11.192.170; nailed=FALSE
008627: Feb 16 00:23:13.077: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostRequestConnection: Posting UDP conn create request for addr=204.11.192.170, port=5080, context=0x4840BD14
+++CUBE succesfully created a connection with 204.11.192.170+++++++++++
008638: Feb 16 00:23:13.081: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerProcessConnCreated: connection instance created for addr:204.11.192.170, port:5080 local_addr=192.168.1.203 local_port=49552
Next CUBE procceeds to send an outbound INVITE
008646: Feb 16 00:23:13.081: //3343/A5A3315A8319/SIP/State/sipSPIChangeState: 0x49630448 : State change from (STATE_IDLE, SUBSTATE_NONE)  to (STATE_SENT_INVITE, SUBSTATE_NONE)
++++++++++++but the INVITE appears to go to cucm when infact it wasnt sent there..it was sent to ITSP!!!!!!!!!!
Sent:
Via: SIP/2.0/UDP 192.168.1.203:5060;branch=z9hG4bKD58157A
From: <>18165297500@callcentric.com>;tag=B46262C-230A
To: <17772253754>
++++NEXT we get a response back from your ITSP requesting authentication++++++++
008670: Feb 16 00:23:13.181: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
008671: Feb 16 00:23:13.181: //3343/A5A3315A8319/SIP/Msg/ccsipDisplayMsg:
Received:
f: <>18165297500@callcentric.com>;tag=B46262C-230A
t: <17772253754>
i: A5AF6643-960911E3-831FFFD7-951695DD@callcentric.com
CSeq: 101 INVITE
Proxy-Authenticate: Digest realm="callcentric.com", domain="sip:callcentric.com", nonce="b69582701157bab55830417b7b62def9", opaque="", stale=TRUE, algorithm=MD5
l: 0
So, even though it looks like the call was sent to cucm, it was never sent to CUCM, it was sent to ITSP for onward forwarding to CUCM!!!!!!!!!!!!!!!!
Aok - Hugely helpful notes!! you were right - I removed the "outbound-proxy dns:callcentric.com" command and calls now ring through to my CUCM registered SCCP phone. When I answer the CUCM phone I receive a couple seconds of silence and then reorder tones. The calling party (18165297500) receives ringback and then an error that the party isnt avaialble from the local telco.
I've attached ccsip all debugs and cucm traces for the failed call as well as a current running config from the cube gateway.
Thank you so much for the assistance thus far - we're making progress
Calling number is 18165297500
Called number is 8452055544 (although the callcentric username 17772253754 is what you'll see in the logs)
Time of call 1:24PM CST
SCCP Phone Mac 001EBE91435C
Andrew
VIP Super Bronze
Excellent..We are making proigress...lookslike you dont like me though You havent rated any of my posts! My last post took all of my brains to figure out ! lol
Okay, Now the call progressed as expected and CUBE sends a 200 OK back to your ITSP..but they didnt respond to the 200 OK. You need to get on the phone with them and find out why they arent sending an ACK to your 200 OK. Come back and update us once thats done. We will then work on the sip profile to sort out the how to copy the TO header to the Request URI
Aok - My appologies, I think i didnt understand how the rating was working (I was rating the wrong posts). I rated your responses - very very helpful :-) Thank you!
I sent a note to the ITSP (Callcentric) and will respond once I hear back from them. They do not have a CUCM/CUBE template but they have been helpful in troubleshooting. They too saw the reinvite back (from the proxy statement) but weren't sure how to explain it.
It makes me happy it was a tough problem - I hate to ask for help on th easy ones
Thanks again and will reply shortly.
Andrew
Deji
My last post took all of my brains to figure out -  +5 for this.
AOK - I received the following back from the ITSP. It looks like they dont like the require timer statement.
From the trace provide we do see the following:
Require: timer
Can you please modify your configuration so that you are no longer requiring session timers? Once you have done so retest calling then update this ticket.
If you have any other questions, please feel free to ask. Thank you.
Thank you,
Andrew
VIP Super Bronze
Ok..Try this...and test again. (if it doesnt work please send debug ccsip messages only)
voice class sip-profiles 5
response 200 sip-header Require REMOVE
voice service voip
sip
sip-profiles 5
Aok - We have sucess! Inbound calls are now sucessful! Talk about a happy day..I still have the DID routing issue, and i need to get outbound calls to include username or a DID on my account to sucessfully route .. but I dont think ive ever been so happy to hear a test call go through.
Here's the info they provide for outbound Caller ID.
To send the caller ID number of a DID on your account or an already verified number within the SIP INVITE message of an outbound call you will need to have your user agent (UA) attach any of the following headers from highest priority to lowest priority, which are supported by most IP PBX's (check your vendor's documentation for support), to your outbound calls:
REMOTE-PARTY-ID
P-ASSERTED-IDENTITY
P-PREFERRED-IDENTITY
Thank you,
Andrew
VIP Super Bronze
For the inbound call..try this...and test to see that calls are sent using the TO header..
request INVITE sip-header TO copy "<>" u01
request INVITE sip-header SIP-Req-URI modify “.*@(.*)” “INVITE sip:\u01@192.168.1.200:5060 SIP/2.0
For outbound calls, I need to know the range of your DDI...What should the extensions map to or do you just want to present a single DDI to your provider for all calls? If that is correct, then what is the DDI you want to use
  Aok - Thanks, I'll give that a shot and see if the calls route correctly (I wont be able to test until this evening).
I have the following DID's
18452055544
18452055545
Outbound I'd want to see where the call was coming from and correctly insert that into the header - I assume something like
sip profile 6
request INVITE sip-header From copy "<>" u01
request INVITE sip-header P-Asserted-Identity modify “.*@(.*)” “INVITE sip:\u01@192.168.1.200:5060 SIP/2.0
And then put that on the outbound dial-peer to Callcentric (ITSP)?
Thanks again for all the assistance
VIP Super Bronze
voice class sip-profile 6
request INVITE sip-header P-Asserted-Identity modify “(.*)@(.*)” "18452055544@\2"
request INVITE sip-header Remote-Party-ID modify “(.*)@(.*)” "18452055544@\2"
Then apply to dial-peer towards ITSP or apply it to existing sip profile 5
sip profiles 5
3921
