Called Number Transformation - How to hide it ?
I have configured a Called Number Transformation within a Route Pattern in order to use an alternate Telco Provider but I would like the users not to see the transformed number (cause it is like a 20-digit number instead of a 11-digit one). How would it be possible to hide this transformation and avoid showing it on the user phone ?
Thanks for your help,
Laurent IGNATIO
Bronze
Re: Called Number Transformation - How to hide it ?
Laurent,
If you do the transformation in your route list configuration instead of at the route pattern, the end-users should not see the transformation.
Jim
If you do it under the Route Pattern level, users will see the modified digits. If it is done at the route list level, users will never see the transformed digits. So to accomplish make the changes at the Route List level instead of the route pattern level.
Thanks a lot, both of you.
I will try to configure it on the Route List.
Thanks again,
Laurent
148
