Called Parked only allows 1 call to be parked?
Why would CUCM 6.0 only allow 1 call to be parked when I have multiple numbers in my call parked available numbers?
THanks!
Community Member
Re: Called Parked only allows 1 call to be parked?
Does the incoming call come into an h323 gateway? If so, make sure that call park numbers are configured on the primary CM that the gateway is sending the call to. There is a bug I ran into on CM 5.1.2, I believe it is in 6.0 as well.
Green
Do we have park numbers for each CCM server in the cluster?
What is the call flow and error u r seeing in the phone
131
