Called party transformation pattern For sip trunk
Hi To all
I used this discussion https://supportforums.cisco.com/discussion/11708211/called-party-transformation-pattern
when i wanted to move  a prefix for my outgoing calls to be showing on the screen of the ip phone..
The old scenario was CUCM--H323 VG--PRI
Now the scenarion is CUCM---SIP VG--SIP TRUNK
I tried the below method which was ok with h323 and PRI BUT now is not apply with the sip trunks
CUCM Config
Route Pattern: 9.00!
- Called Party Transform: Predot
Route List: YourRouteList
- Called Party Transform: Predot / Prefix 91018
H323 GW Config
Keep the dialpeer as is and add the following:
voice service voip
no supplementary-service h225-notify cid-update
Can you share your thought?
Please rate all useful posts Regards Chrysostomos ""The Most Successful People Are Those Who Are Good At Plan B""
From what you have said above
From what you have said above, I'm guessing you want to show the number that is displayed on the user phone as 91018 ... right?
What is happening right now? What is the user seeing on the display?
Could you provide an example of what number the user dials and what he should see?
Hi Sreekanth 2  The previous
Hi Sreekanth 2
The previous post was for an old issue
Now we have sip trunk from CUCM to VG and from VG TO SIP TRUNK(ISP)
We want to move the prefic in front of the dialed number examle we use 88xxxxxxxx and then hit a specific dial peer into the voice gateway , remove the 88 and send the remaining digits to the Sip trunk ...
The issue is a have followed the previous case from teh old scenario (cucm-h323 vg--pri) but now is not apply to the sip
In h323 is a command no supplementary-service h225-notify cid-update BUT in the sip does not exist.
I use also no update-callerid into sip but again the same issue
On the screen of the phone i still see 88xxxxxxxx
So right now, you do not want
So right now, you do not want to see the '88' and the number should only be xxxxxxxx. Am I right?
Hi We want to add 88 in front
We want to add 88 in front of the call to hit the specific dial peer BUT we want to remove the 88 of the screen of the ipphones
When someone dial outside is dial 9xxxxxxxx. Then we remove the 9 and we add 88 in order to reach the specific dial peer as i mentioned before
But with this way the caller see on the ipphone 88xxxxxxxx.So we want to remove the 88 from the user ipphone screen
You have mentioned that you
You have mentioned that you will remove the 88 before sending this to the provider right? Is this done using a translation pattern on the gateway?
Also, have you taken a look at the debug ccsip message on the gateway to see what the RPID/PAID values are?
I'm not sure if disabling the update caller-id would help.
Hi AllI am using trnaslation
Hi All
I am using trnaslation rule to move the prefix before to send the call outside to the provider
Example:
voice translation-rule 1
 rule 1 /^88/ //
voice translation-profile SIP_Outgoing
translate called 1
Dial peer voice 88 voip
translation-profile outgoing SIP_Outgoing
destination-pattern 88T
incoming called-number 88T
We remove the 88 but on the screen its show 88xxxxxxxx.On the dialed numbers does not appear the 88 in the front of teh call
Could you paste the debug
Could you paste the debug ccsip message from the router while making a test call please? I'd like to take a look at what the gateway is sending the call manager.
263
